Uconnect 5 no text option for IPhone 12?
Big Tup
Leesburg, VA
Hi,
Is there a software upgrade that allows the Uconnect 5 work with Iphone 12 for text messages (12 inch screen on a 2022 Ram 1500 Limited Longhorn)? My iphone works with the Uconnect for calls, but not messages as i get a message saying "phone not supported for messaging"
bill-e
New Hampshire
Try deleting it and reinstalling and make sure you click on Yes to the dialof asking if you want to download messages when initialling re-pairing the phone.
Fatherof3
Ontario Canada
Hi,
I’m not sure if it would be the same as mine but I have to have my phone plugged in to get text messaging through the truck .
Big Tup
Leesburg, VA
thanks. i did do that, to no avail....in fact the "do you want to download messages" message doesnt even come up.
Big Tup
Leesburg, VA
thanks. that's odd. i have a Google Pixel phone that work fine without being plugged in. it's odd that uconnect clearly states "phone is not supported for messaging" vs it being a configuration or setup error.
bill-e
New Hampshire
Did you totally delete the phone from the truck and "forget" the BT connection on the phone?
Now here's the real bummer about Uconnect and text messages. When Uconnect went to having Android Auto and Carplay as a feature, Uconnect no longer has built in Speech to Text messaging, only some pre-defined responses. So if you actually want to be able to respond to a text, you have to use either Google or Siri, either directly through the phone or with Android Auto/Car Play, to perform the speech to text.
Big Tup
Leesburg, VA
As it turns out, I am able to used messaging/text without Carplay. I needed to "turn on notifications" in the Bluetooth settings of my IPhone.
wsutard1
CarPlay should be sending your texts from the phone to the CarPlay system. They won’t show up anywhere but in CarPlay but they should be there. It’s an apple function. Has nothing to do with Uconnect.
Big Tup
Leesburg, VA
Thanks. I am not running CarPlay. But I am receiving texts without having CarPlay on, simply because i needed to turn on notifications on my cell phone.
maxweenus
I have a pixel 5, 22 Limited/12 in uconnect.
It will not allow 'messages' to work.
Are you saying the pixel shows messages?
Very curious to know as I get a not supported message and on the web url provided pixel isn't listed.
Big Tup
Leesburg, VA
I had a pixel xl and a pixel 3 XL working fine on mine....make sure your notifications are on in your phones settings and ensure that when you initially pair your phone that you allow it to access contacts and messages
BParker03
Hi,
Go to settings on your phone, select Bluetooth, find the uconnect line where your phone is paired, hit the blue i out the right. Then turn on Show Notifications. That should fix it.
m.hamner
what advantages do you have over using the uconnect system itself over the native iPhone interoperability with CarPlay? curious to see what I'm missing here.
Carplay doesn't support text messaging while driving anymore. My wife's 2020 Traverse won't show texts or notifications for her iPhone at all. She can make and receive phone calls, but no texting
Jimmy07
Honorary Site Supporter
I might be misunderstanding what you’re saying, but I can send and receive texts via CarPlay while driving.
Was just a thought. I know my wife's Traverse doesn't allow it
