FCA should have the updates hosted on a website for people to download them.It's generally a pretty bad idea to modify the update files. I have a buddy that used to work on UConnect and explicit instructions are to always to use the zip as provided. There are other items in the "map" files besides maps and changing the updates best case fails out and worst case bricks the radio with the middle ground of potentially causing issues that you don't know yet.
If you don't like it, you don't have to download it. You can click cancel as soon as you see the file size. This type of stuff isn't exactly driving us to work on hunting down new versions or bugging my friends that work at FCA about updates. If the USB updates bug you, no one is twisting your arm to download and install them; just wait it out for the OTA. You can't have it both ways of complaining about slow OTA rollouts and then complaining about the updates when someone provides the download.
It's not, it's a new version for MY23. Don't try to load the MY22 release. I think the ties into the digital dash requiring their own release with the nav and such that display into the dash.Strange that a brand new truck would be different than the latest release. Fca-my23.t25.48-PROD is my current version.
Thank you! You've been amazing! Your updates have gotten me out of the run around at the dealership that didn't even try to do a USB update when my truck was still on 24.xx They even lied and said they tried and it failed with some password prompt. Good God, I'm in the IT field and even I know there's no password prompt for the updates. Went home and got your first update and loaded without issue. The same thing for 26.17...just had to get a bigger USB drive and worked without issue.Unbelievable!!
This is basically why I stopped sharing updates on this forum, except through PM. People beg for it repeatedly, then when they get it, they cry and complain.
That’s the update that was received from a dealership, and that’s how it was packed up. Go to the Stellantis site to update the maps to the newest.
I echo this Jimmy. Without the 26.15 file I’m convinced I would never received an OTA update to 26.17. I was stuck on late 2021 firmware prior to side loading it.Thank you! You've been amazing! Your updates have gotten me out of the run around at the dealership that didn't even try to do a USB update when my truck was still on 24.xx They even lied and said they tried and it failed with some password prompt. Good God, I'm in the IT field and even I know there's no password prompt for the updates. Went home and got your first update and loaded without issue. The same thing for 26.17...just had to get a bigger USB drive and worked without issue.
I appreciate your support and uploading these updates. I'll take the risk as I'm tired of the OTA rollout not working, Stellantis NOT providing downloads, and dealers that honestly do not try or at least seem to do the minimum and then tell customers BS responses when they ask. I knew they didn't try the USB option and they could have just said that.
BTW Stellantis, the dealership ordered an entirely new head unit as the solution. That's easily a $1,400 repair for something that was solved with a USB update provided by Jimmy07. After I told them it was fixed, they still wanted to swap the head unit. WTH.
Same Here - Thank you Jimmy07! The info and downloads you've shared have been very valuable to me and I am very appreciative of your time and effort. I also never got an OTA update until I installed 26.15.I echo this Jimmy. Without the 26.15 file I’m convinced I would never received an OTA update to 26.17. I was stuck on late 2021 firmware prior to side loading it.
If it were mine, I'd be very dubious and think the risk isn't worth the reward, but since it isn't mine, I say go for it!Before I write anything further you guys need to know that I have a 2022 1500 Longhorn 'European version'.
I downloaded this firmware S26.15 and checked with my original firmware that I have from the importer AEC (downloaded from their website).
Because the Uconnect system does not function well I am looking for other firmware.
But...not only do both files differ a lot in size, they also contain different folders and files.
What do you guys think? Should I try to update or should I not?
I don't care about the fact that I maybe would lose the Dutch language.View attachment 153159View attachment 153160
The one on the right has North America maps pre-loaded (you can tell by the size of the nav_payload.bin file). If you have Euro maps, it likely would wipe them out. I only know how to get North and South America maps, not Euro ones.Before I write anything further you guys need to know that I have a 2022 1500 Longhorn 'European version'.
Interesting. I haven't heard of a version higher than S26.17. I wonder if this is a special version for the Middle East, or if we will all be getting that version?Just got my truck fresh from the dealership and I got this new firmware version!
On your previous posts, it looked like your trying to manually install the S26.17. But you say now you got the truck fresh from dealership. Im a bit confused here, did the dealer install the S27 on the same truck ?Just got my truck fresh from the dealership and I got this new firmware version!
