Turning off the headlights
OK, thank you. I'll look into alfaObd. I have another 2 months or so to get it figured out before open water season.
I had no idea the Canada models kept the lights on even when turning the headlight knob all the way off until I was running into the store the other night. Left my buddy in the truck with it running and couldn't get them to go dark with the truck on!
Canada requires DRL, and Ram has to remove then option to disable them through settings menu on radio. You just need to change your country of origin to US, IIRC and you will then have option to turn off DRL in radio settings.
Thanks, I am in the U.S., and it is the main headlights, and I will have to poke through screen options. It would just be nice if I could turn off the main headlights when pulling in to a a location with lots of people at night so I don't blind everyone, since the headlights are bright.
Were you able to figure this out? I'm new to a 2020 1500 Bighorn and my low beams are on 100% of the time, regardless of the position of the dial. I don't see any settings on the Uconnect display that would allow me to disable daytime running lights.
Assuming this isn't a Canadian truck, you should have a "Lights" menu in your UConnect4 settings.
If your daytime running lights are active, you can disable those if you're in the US through your radio. If you have a Canadian truck they're on all the time. If you're talking about the accent lights on the top and bottom, no you can't turn them off without a Tazer DT.
So I am in the US, but my 2019 Laramie Longhorn was originally a Canadian truck. Is there any way for me to update my location?
Fairly certain there is an AlfaOBD setting for Canadian or not to determine DRL's being an option.
