Turn signals as DRLs are cool
Eighty
Moderator / Dream Killer
I didn’t realize it was possible to turn the uppers and lowers Amber like that, except on a TRX. How was it done? Or is it a trick of the light, and only the lowers are Amber?
Rebel2022
Alberta Canada
Turn signals are amber, signature lighting is white. Or signature off and only amber turn signals on if you prefer
MurphBigHorn
I like the way these look myself too. Using them on of the time has daylight running lights. They both have blown already though and had to replace them. Looks a lot better in person.
Darksteel165
Massachusetts
The top of his truck is white
Those headlights OP has are differnet then the Limited\TRX ones.
His blinker is the bottom brow.
On a limited the blinker is the top brow.
theblet
Looks good! You could maybe replace with led bulbs that way they wouldn’t burn out and would be brighter.
theblet
Now turn on the mirror turn signals as DRL too!
I wish I could do this through jscan! From what I understand it’s a wiring harness that’s needed to do that. I’ll prob add some rebel style grill lights at some point
theblet
Using my Tazer I just did the amber turns for DRL and deactivated everything else.
With the latest Tazer upgrade I can add the amber mirror turns as well but chose not to do that. A bit too much for me.
I may try this as it does look good.
mynameisante
SD
Anyone with a white Rebel that has this mod?
Also, how can I do it? Is it in my settings, or do I need a programmer?
Scram1500
I wonder if this works on aftermarket headlights, one of the advertising pictures for Morimoto has the amber blinker illuminated Screenshot_20230910_070222_Chrome~4.jpg
