Turn signals as DRLs are cool
I didn’t realize it was possible to turn the uppers and lowers Amber like that, except on a TRX. How was it done? Or is it a trick of the light, and only the lowers are Amber?
Turn signals are amber, signature lighting is white. Or signature off and only amber turn signals on if you prefer
The top of his truck is white
Those headlights OP has are differnet then the Limited\TRX ones.
His blinker is the bottom brow.
On a limited the blinker is the top brow.
I like the way these look myself too. Using them on of the time has daylight running lights. They both have blown already though and had to replace them. Looks a lot better in person.
Looks good! You could maybe replace with led bulbs that way they wouldn’t burn out and would be brighter.
Now turn on the mirror turn signals as DRL too!
I wish I could do this through jscan! From what I understand it’s a wiring harness that’s needed to do that. I’ll prob add some rebel style grill lights at some point
Using my Tazer I just did the amber turns for DRL and deactivated everything else.
With the latest Tazer upgrade I can add the amber mirror turns as well but chose not to do that. A bit too much for me.
I may try this as it does look good.
Anyone with a white Rebel that has this mod?
Also, how can I do it? Is it in my settings, or do I need a programmer?
I wonder if this works on aftermarket headlights, one of the advertising pictures for Morimoto has the amber blinker illuminatedScreenshot_20230910_070222_Chrome~4.jpg
