jeffjcalweb
- Apr 4, 2022
Hi - I've used AlphaOBD and am using an ODBLinkMX+
AlphaOBD is connected to the ODBLink, I can select the model, select feature (radio frequency hub), select the procedure to start (read pin) but then it just coming back to "no data / can not read ECU" or something similar worded.
I am pulling OBD data - tested this by using the actual ODB app on the same tabled I'm using AlphaOBD on - and I can also see some data when connected with AlphaOBD as well - so this seemed like a super easy thing to do but clearly I'm missing something. I have tried this with the truck running, truck with ACC only, radio on, radio off, etc.
Any suggestions?
Thank you!
Any suggestions?
Thank you!
