TRX wheels and tires on a Rebel
Dang that looks awesome! Do you think spacers could be avoided with a different UCA?
Care to comment on your MPG difference with this setup?..
What is the minimum size spacer needed for the TRX wheel swap on a 2020 rebel? I’ve seen mixed opinions through the different threads. Just wondering if anyone knew specifically. I just bought my wheels and I’m looking for a bare minimum set up without extended lugs or a lift kit
What did you finally do with the spacer situation?
I don't have a Rebel, but I have trx takeoffs on a Laramie and used a 0.25" spacer (didn't extend the lugs), and used Mopar A arms and there's enough clearance. I think if you use aftermarket A arms that protrude closer to the tire you might need a bigger spacer.
I have a Laramie as well. Good info Thank you
My wife caught me taking a photo of my truck and just shook her head 😅 here's the Carli commuter lift with rebel rear springs in my Laramie with trx take offs and the 0.25" wheel spacers. Rides nice.
That looks amazing! I hope mine comes out the same way. I'm suspicious its the color combo that makes it so epic.
White may not look as good, but we will find out sooner than later. I bought 1.5 spacers so I'll probably be returning them.
The only thing worse than a narrow look is a skateboard look. Actually they are a tie since I won't be happy with either.
Does this have a level or 3.5 lift?
Carli commuter kit. Not a full 3.5" lift. But taller than a leveling kit. Carli has actual dimensions and details on their site.
