1BADRAMLIMITED
Yes 100%Curious, im thinking of doing the same thing but I have factory air suspension. Can I get buy with just the front links and 1.5in spacers?
What did you finally do with the spacer situation?What is the minimum size spacer needed for the TRX wheel swap on a 2020 rebel? I’ve seen mixed opinions through the different threads. Just wondering if anyone knew specifically. I just bought my wheels and I’m looking for a bare minimum set up without extended lugs or a lift kit
I don't have a Rebel, but I have trx takeoffs on a Laramie and used a 0.25" spacer (didn't extend the lugs), and used Mopar A arms and there's enough clearance. I think if you use aftermarket A arms that protrude closer to the tire you might need a bigger spacer.What is the minimum size spacer needed for the TRX wheel swap on a 2020 rebel? I’ve seen mixed opinions through the different threads. Just wondering if anyone knew specifically. I just bought my wheels and I’m looking for a bare minimum set up without extended lugs or a lift kit
I have a Laramie as well. Good info Thank youI don't have a Rebel, but I have trx takeoffs on a Laramie and used a 0.25" spacer (didn't extend the lugs), and used Mopar A arms and there's enough clearance. I think if you use aftermarket A arms that protrude closer to the tire you might need a bigger spacer.
