TTU14
Finally put on the TRX takeoffs I picked up a few weeks ago!
I found all the info I needed in various places on this forum and youtube, but figured I’d try to condense it into one post for anyone interested in doing the same.
Overall, I really happy with how it turned out! I've put about 500 miles on everything so far including lots of highway driving and some towing with no issues.
- Lift/Level - You need to at least be leveled. I used Bilstein 5100 shocks in the front set at position 5 - the highest setting Bilstein recommends for Rebels and other trucks with the factory ORP. I did not touch the rear suspension. Along side the level, I installed Rough Country UCAs to correct the ball joint angle, and SuspensionMaxx end links to to correct a knocking noise I picked up after install.
- Spacers- You will need spacers to clear the UCA. I ordered 1.5in Bora spacers directly from Motorsport-Tech. They are made to order and have a 3-6 week lead time, but they're worth the wait. There are cheaper spacers available on Amazon and eBay but I personally wouldn't trust them.
- TRX wheels do have pockets on the back side of the wheel which allows for smaller spacers. I've seen other people use 1.25s and as small as .5, but I wanted a little bit of poke. The 1.5s left me with about an inch of gap between the tire and the UCA.
- Rubbing - They will rub, but it can be fixed. I rubbed the fender liner and the factory mud flaps. To fix, I removed the mud flaps and then trimmed about an inch off the plastic liner. It is thin and is easy to trim with a good utility knife. There is a plastic push fastener that secures the bottom of the liner to the wheel arch. I trimmed to about where that faster was, but was still catching the metal bracket behind it. I removed the fastener and hammered the small bracket flat.
- TPMS - I was lucky that this set came with the TPMS sensors still installed. My truck detected them and displayed the pressures automatically after 3-5 miles of driving. If you have a Rebel, your door sticker and TPMS both call for 55PSI front and 45PSI rear which is too high for these tires. Checking the TRX forums, it looks like they are supposed to be at 38PSI. I was able to change the target pressures pretty easily with AlfaOBD. If you've never used AlfaOBD, you'll need a few things. There are other ways to change these settings, but this is what I used:
- The AlfaOBD software which can run on Android devices or Windows computers. I have it running on a cheap Amazon Fire Tablet and paid $50 for the app on the Google Play store.
- A Bluetooth OBD scan tool, I used the OBDLink MX+: https://www.amazon.com/dp/B07JFRFJG6?psc=1&ref=ppx_yo2ov_dt_b_product_details
- A security gateway bypass adapter: https://www.amazon.com/dp/B08ZL4LRVK?psc=1&ref=ppx_yo2ov_dt_b_product_details
- Tire Size/Speedo Calibration - Larger tires will make your speedometer read slower than you are actually driving. Mine was off by 5-6mph at 60mph according to the GPS readout on my radar detector. There is an option in AlfaOBD to change the tire size. You can enter the new size in mm or choose from one of their pre-created tire profiles. I've read horror stories of people entering certain sizes that accidentally disables the ParkSense system. Idk if that is specific to certain years or what, but I did not experience that problem. I used the option for Toyo AT 35/12.5/18s based on another post I saw and it got the speedo dead accurate.
