Truck not returning to Normal mode from Aero mode
1Raider
Has anyone else with the 4 corner Air suspension noticed there truck not retuning to Normal mode after being in Aero? Mine was working fine at 1st but has started doing that. Is there a way to reset it or something?
GeorgiaBoy
Georgia
Mine does this too. Haven't looked into finding out why yet.
Scap
Is your suspension set to normal?
I leave mine in aero for the most part, but if I toggle it to normal it will raise and lower as called for by computer.
mikeru82
The Palouse
I ran into this last year. IIRC, to fix it I disabled aero mode (using uconnect settings) with the suspension at"normal" height. Then re-enabled aero mode. It should work as expected after that. Pretty sure it got messed up by disabling and enabling aero mode while the suspension was at "aero" height.
GeorgiaBoy
Georgia
Thanks, I’ll give that a try!
GeorgiaBoy
Georgia
At what speed should Aero kick in?
Try reading the manual dufus!!
From Normal to Aero between 62mph - 66mph for twenty seconds
Or 66mph and above.
Goes back to Normal between 30 and 35 for twenty seconds
Or drops below 30mph
I'll test tomorrow!
1Raider
Thanks mikuru82 i'll try it tomorrow and see if it helps..
GeorgiaBoy
Georgia
Or 66mph and above.
I'll test tomorrow!
It worked! Had to get to 70 for it to drop to Aero but it may have been activated at 67 but I was at seventy before I noticed it.
Went back to Normal when my speed dropped to the low 30‘s
Thanks ya’ll for figuring this out!!
1Raider
Truck is back to not going into Normal mode after getting off the Hwy once again.
Not sure what the deal is as I've tried turning Arero mode off and back on with it in Normal mode again and didnt help....
Anyone else's rig doing the same?
