So my bass boat trailer has surge brakes and not electric. I put the truck in "Tow/Haul" and the blind spot activates smoothly but the truck won't let me track trailer miles. Will it only do that with electric brake equipped trailers?
Did that. No effect.
Did you try what @Ramit392 suggested? If you havent had the chance, please let us know as the conversation wasn't resolved originallyI have a light hybrid snowmobile trailer that has LED lights, but no brakes, so it only uses the 4 PIN trailer connector.
The Trailer Trip computer (trailer trip miles) doesn't register at all.
The manual has no clues as to how to get the trailer trip odometer to start registering.
Here's my thread on it.
https://5thgenrams.com/community/threads/towing-trip-computer.5646/
I tried searching, but didn't find this thread until someone pointed me to it.
It only works with the pulse from trailer brakes. Figure out how to get the pulse and it will work. Otherwise...it is not gonna happenIs there any way that anyone knows to get the trailer odometer to work on trailer without bkakes?
4 flat connector.
It works with 7 pin connector and trailer with brakes.
2021 Ram 1500 Limited
The trailer odometer tracking is a function of the integrated trailer brake module via the electric brake feed circuit from the module to the 7-way connector. The 4-way connector has nothing to do with the trailer brake module, as it only uses ground, park lamps, left turn/stop, and right turn/stop lamp circuits. Therefore, there is no way for the trailer brake module to track mileage on something plugged into the 4-way connector. One thing you can do is plug a 7-way adapter in that has a resistor from ground to electric brake feed at the same time you are using the trailer that is plugged into the 4-way. Then the trailer brake module will see something plugged into the 7-way port to be able to track mileage.Is there any way that anyone knows to get the trailer odometer to work on trailer without bkakes?
4 flat connector.
