Ok that makes more sense!Oh wow, 1600+ is impressive! so taking into consideration the mods let’s say you added about 250 pounds. I’d keep payload under ~1400.
Wheels and tires are apart of a vehicles “Unsprung weight” even though the suspension does not hold up the weight, it still is apart of the truck, if you think about it, the axles are not held up by the suspension and they are included in the trucks empty weight.
So when you said 11,180 he took that and subtracted it from GCWR 17,000 (5820) then took 5820 and subtracted it from gvwr 7100 getting the 1280. Your towing by j2807 is 11,180 but by the numbers it’s actually 11,543.
The chart is a little generic because it gives the weight “based on trucks with the most common options (over 33% of the trucks have the options)” according to the disclaimer.
So your numbers are correct, because: GVWR is 7100. Payload is 1643. Meaning curb weight is 5,457. Subtract curb weight from 17,000 GCVWR and you get 11,543 which is exactly what you said.
I still personally kinda disagree that wheels/tires subtract from your available payload though - and even when I googled it I saw plenty of arguments on the forums lol so I don’t want to argue. I get it, payload = gvwr - curb weight, so if I add weight to the tires, it makes the curb weight higher. I just feel like they are adding weight & drag, but not pressing down on the suspension or the axles more like actual payload would. So if I added 250lbs in wheels and tires, it makes more sense to me to just pretend I’m towing a trailer that’s 250lbs heavier, versus saying that the full 250lbs is taking away from my available payload. If you guys disagree that’s fine lol I’m content with agreeing to disagree.
