Still clear as mud... One person says I can add two people at 150 lbs ON TOP of the payload number. SAE is unclear with all their "assumptions" but no one clearly stating the impact on their own numbers. Absolute statements from conflicting sources say something else.
I'd like to see here....
If you go to the RAM website https://www.ramtrucks.com/towing/towing-guide.html and enter your VIN number, you can see the towing capacity of your specific vehicle. You should also look at the sticker on the inside of your door to compare. Generally speaking "max payload" will be the limiting number in relation to what you can tow as you look at your numbers.
Ram is "compliant" with SAE J2807 that provides the standard for towing for the industry. This standard, in relation to payload makes assumptions as part of the standard including a standardized weight for passengers, and towing equipment.
THE TWO WAYS IT COULD BE EXPLAINED
Compliant means that the max payload indicated by your VIN number for your specific truck means that you do NOT have to count 300 lbs for passengers or 69 lbs for towing equipment and that 369 lbs can be on top of your max payload raising your actual payload by that amount.
OR
Compliant means that the 300 lbs for passengers or 69 lbs for towing equipment and 10% tongue weight in the SAE J2807 is incorporated into the VIN number based max payload number. As a result, you must add all added weight including occupants, towing equipment and tongue weight together to assess whether your max payload number is exceeded. Any weight other than the original equipment used to establish the "max payload" MUST be counted to assess your actual payload in a given situation.
My thought is that the latter "or" is true vs the former "wishful thinking on my part" way to assess actual payload an individual can tow.
I'd sure love to see something like that. They key concept is establishing what the impact of the SAE J2807 standard is on the term "compliant."
OR
