I've had a 2019 1500 for a little over a year now, I bought it with 24k miles on it, and currently I'm hovering around 38k miles. This truck has been nothing but problems. If I could walk away from this thing for what I owe on it I would do it and not even think twice about it. The biggest and most persistent problem that I'm having is a leak that keeps soaking the front passenger side carpet. I've had the truck in 3 separate times, the first time while it was still under factory warranty and all I can get from the dealership is "we sprayed water on it for a little bit and didn't see any leaks anywhere". I just got it back today from a different dealership who basically said the same thing and said that the ac drain line isn't clogged. I asked them if they would try to contact Ram directly and see what we can do here as this is a documented problem I've had since before the factory warranty ran out and they basically told me to pound sand, gave me the number to call and told me to do it myself. So I guess I'm just wondering if anyone has had any luck doing so or if you guys have any opinions or ideas what to check.
