I got mine. Had to spend an entire day with tech support as mine would not marry at all and firmware 18.0.3 had no menu functionality at all, just the shortcuts worked.
I've got it working on a base flash of 18.0.1 and got it to marry after performing a full reboot first. I like what it does, but it is far from plug and play or friendly and needs a LOT of polishing and serious debugging IMHO as an engineer. I've built my own obd2 raspberry pi's to hack the canbus by replaying commands on other vehicles.
I'm pretty sure there's a new BCM firmware my truck has that is causing the issues specifically module 8. Waiting to see what z automotives engineer says.
How do I reach her direct? Is there any price cut doing this? I apologize if this info is in this thread as I quickly browsed through it and may have missed some info. ThanksAll...quick update for those who are considering placing an order.
I had been forwarding your contact information to Samantha, but given the deadline is approaching, I would ask that you reach out to her directly. This way you can cut out the middle man and hopefully ensure you make the deadline. I would hate if you missed out.
Best Wishes
I bought mine with my amex, they'll just buy me a new one if it craps out.Is it worth buying the tazer warranty?
without hitting the brake push the start button twice to be in run mode.Anyone know how to remove this thing?
It's not the tazer. It's the crap grounds on your truck.Got mine fitted on Thursday. Difficulty getting it to do what I wanted but pretty much got it sorted. Friday the remote start wouldn’t work. Today the vehicle won’t start at all. It also won’t lock; even removing the Tazer doesn’t remedy it. Had to borrow a vehicle to get to work today (work in the Hospital). The truck is completely dead bar the proximity lights on the mirrors on solid. Have emailed support. Will detach battery tomorrow, leave it for a bit, reattach and see if that fixes it. Got to be honest, wasn’t expecting losing the use of the truck.
Thanks, make its it an expensive purchaseI got mine today.
I was able to marry mine up with my truck with minor difficulties, and here's why.
After carefully going through the module, I realized that mine was uploaded with the 18.0.1 software.
I however was trying to follow the instructions of the 18.0.3
Once I realized my mistake, I downloaded the corresponding instructions to the said software; it was pretty straight forward after that.
Another important note to all my Canadian friends, there was an additional cost of $71.32 for taxes when the product crossed the border... just an FYI. Thanks Trudeau!!!
The grounds were done on the recall before I purchased. Had zero issues with the truck since delivery August year until I added this mod.It's not the tazer. It's the crap grounds on your truck.
Has anybody figured out how to keep the light show on while the vehicle is in motion?
