larkcorey
- Oct 9, 2023
Hi all, I plan on adding some led strip lights to the bed. I read some great threads to plan out how I am going to do it, but still have a couple questions that I couldn't find an answer to.
I plan to wire the lights to a constant power source from the hitch harness. Should I tap into the wire with a t-tap or should I connect to the back of the 7pin connector? If so, what is the hardware bits that I would need? Thanks!
