Tapping into hitch harness
larkcorey
Hi all, I plan on adding some led strip lights to the bed. I read some great threads to plan out how I am going to do it, but still have a couple questions that I couldn't find an answer to.
I plan to wire the lights to a constant power source from the hitch harness. Should I tap into the wire with a t-tap or should I connect to the back of the 7pin connector? If so, what is the hardware bits that I would need? Thanks!
theblet
Most people use this curt harness
He would have to cut and splice for the constant power. There isn't a constant power wire in the 4-pin wiring
Brutal_HO
The Mad Irishman
Douglas County, CO
larkcorey
I used this on my HD. $42.
Built in sacrificial 5-wire. Extras wire is reverse you could repurpose for constant power and replace the plug with a 4-wire if you need one.
ETA: There's a full on 7-pin T-harness for adding an in-bed 7-pin, let me see if I can find it.
So this connects between the existing harness and the back of the 7 pin connector? I can simply tap into the 5 wire for power? Is there a connector that I can add to the hot wire from the new lights or do I splice into it?
Andymax
5thGenRams Supporter
Columbus, OH area
FWIW I spliced into mine for both strip lights in the bed and accessory reverse lights mounted to my trailer hitch. Pretty easy if you're comfortable with splicing.
Brutal_HO
The Mad Irishman
Douglas County, CO
You could either get the cheapest 7-pin bed harness and use #4, or any of the other 4 or 5-pin (cheapest) and repin to use #4 for 12V power.
I got the 5-pin because it had the reverse light wires I needed to setup some relays for lighting controls on my 5th wheel, without all the others I didn't need. I simply plugged in a mating 5-pin just to pull the reverse lead with cutting anything.
If all I was looking to do was pull 12V, I'd get the $22 Curt 55384 @theblet linked, repin #4 to one of the other present in the 4-flat, and use a mating 4-flat to pick the 12V.
Goodboy
I'm confused... Why wouldn't exposing the necessary wires in the harness and taping into them be the best way?
I haven't looked behind my bumper yet but I'd assume doing a proper wire tap is cheaper than a 50 or 100+ dollar harness...
Let's see your version of a "proper wire tap."
I meanz if you want to call out someone's wire taps, while suggesting they splice a 4-pin harness to whatever they want to power, then they probably would use crappy splices as well.
theblet
Because using a harness doesn’t require you to expose or open any factory wiring whatsoever. You can go back to 100% stock.
True, but you know they are using cheap crimp on butt splices on the harness.
