Tapping into hitch harness
larkcorey
Hi all, I plan on adding some led strip lights to the bed. I read some great threads to plan out how I am going to do it, but still have a couple questions that I couldn't find an answer to.
I plan to wire the lights to a constant power source from the hitch harness. Should I tap into the wire with a t-tap or should I connect to the back of the 7pin connector? If so, what is the hardware bits that I would need? Thanks!
Most people use this curt harness
He would have to cut and splice for the constant power. There isn't a constant power wire in the 4-pin wiring
I used this on my HD. $42.
Built in sacrificial 5-wire. Extras wire is reverse you could repurpose for constant power and replace the plug with a 4-wire if you need one.
ETA: There's a full on 7-pin T-harness for adding an in-bed 7-pin, let me see if I can find it.
So this connects between the existing harness and the back of the 7 pin connector? I can simply tap into the 5 wire for power? Is there a connector that I can add to the hot wire from the new lights or do I splice into it?
FWIW I spliced into mine for both strip lights in the bed and accessory reverse lights mounted to my trailer hitch. Pretty easy if you're comfortable with splicing.
You could either get the cheapest 7-pin bed harness and use #4, or any of the other 4 or 5-pin (cheapest) and repin to use #4 for 12V power.
I got the 5-pin because it had the reverse light wires I needed to setup some relays for lighting controls on my 5th wheel, without all the others I didn't need. I simply plugged in a mating 5-pin just to pull the reverse lead with cutting anything.
If all I was looking to do was pull 12V, I'd get the $22 Curt 55384 @theblet linked, repin #4 to one of the other present in the 4-flat, and use a mating 4-flat to pick the 12V.
I'm confused... Why wouldn't exposing the necessary wires in the harness and taping into them be the best way?
I haven't looked behind my bumper yet but I'd assume doing a proper wire tap is cheaper than a 50 or 100+ dollar harness...
Let's see your version of a "proper wire tap."
I meanz if you want to call out someone's wire taps, while suggesting they splice a 4-pin harness to whatever they want to power, then they probably would use crappy splices as well.
Because using a harness doesn’t require you to expose or open any factory wiring whatsoever. You can go back to 100% stock.
True, but you know they are using cheap crimp on butt splices on the harness.
