Updating this thread. Installed the Putco Blade red/amber/white light bar with the Putco wire harness.
60”, SKU: 92009-60
https://www.putco.com/blade-led-tailgate-light-bar
Blade Quick Connect Harness
SKU: 529004
https://www.putco.com/blade-quick-connect-harness
Light bars looks fantastic and works as advertised. Reverse is super bright. For an extra effect, the red LEDs light up the entire cavity under the tailgate. I’m pleased with the purchase.
Installation took 2 hours. I took my time and had a couple interruptions. Opted to install with stainless steel, self-tapping screws and spacers. This allowed space behind the bar for the camera wires. Hardest part was lining up the holder brackets. I had several plastic spacers on hand from another project and just combined them until the brackets were level with each other.
The wiring harness webpage shows the white (reverse) wire with a connector. It arrived with the white wire cut about 1 inch out of the shielding. Pretty tough to splice. The light bar white wire was simply stripped and had no connector. I was a little disappointed with the difference between the product and the webpage. Not difficult to overcome though.
There is a delay between the truck turn signal and light bar. No biggie for me. Be advised if this is a concern for you.
Thanks for the posts in this thread. They helped a bunch.
