Tailgate light bar
It is because it is a four wire setup. Brake and blinker are on the same side in the same wire. The lightbar needs to wait and determine if it is constant power(brake) or pulse power(blinker). At that point it lights up accordingly. I thought it would annoy me as well and almost went with a different setup but in the end I am very happy with it.
Thank you for explaining that. One more question then if you know. If you just quickly tap the brakes how does the light bar respond. Will it blink a half second later (after your brake lights are off) or not come on at all?
Now that is a good question. I will have to try it when my wife gets home and let you know!
Did you get to complete the permanent install? Just wondering how the final install went (any problems or anything to look out for? ) and if the Curt harness is working nice with the BLIS, cross traffic, and advanced safety group. Getting ready to pull the trigger on the triple.
So for a LImited, this bar won't affect any of the electronic tech in the rear end (BLIS, cross traffic, sensors, trailer detection, etc)??
I think it looks fantastic and a good option for protection from following texting and snoozing.
I also have all of that. Doesn’t affect any of it.
The above is just an option for those wanting, I still prefer the triple light system instead.
Has anyone tried the flex version by chance? Seems it would give little more flexibility to the whole mounting delimma with the wiring harness area...
http://www.opt-7.com/redline-flx-flexible-led-tailgate-light-bar/
I think the main problem is the area where you would mount it isn’t flat on the 2019s. You would end up with a light bar that curves inward. Not sure what that would do to the appearance but I feel like it wouldn’t look as good as one that was straight.
Agreed Grinch. I want the triple bar but worried over the connection venture (wiring) and the actual mounting. I did this same bar on my son's 2007 Ram and it was a breeze.
It’s easier than you would think. I did it in around 30 mins. Looks great.
Can't wait. I have the triple and just waiting on the Curt adapter and cable organizers. What method did you use for the wire tap? Curt taps or ole fashioned cut n wrap?
I used a curt 5 way adapter and then made my own harness for the light bar. I didn’t have to splice anything, not even for the reverse!
Yeah, I saw your write-up and picks. @grinch72 , This was more for those that used the Curt adapter with the 4 blade and had to tap into the middle white wire.
Maybe I missed it somewhere, but whats the big deal with the Curtis adapter? Plug in 4 pin adapter and run a wire to the reverse. No? Or is there something about all the systems these trucks have?
It allows you to have a nice clean install with all the wiring hidden behind the bumper. Plus the cable that comes on the lighter really isn't long enough to reach back to the regular 4flat connector on the vehicle.
I also used the metal clips that came with the triple to mount it to the truck. See clips and spacers along with tailgate clearance in attached pics.
How did you mount these clips?
I don't have my bar yet, but did you find a convenient existing hole to mount them into or do you need to drill a couple to get the clips in the right place?
I get the part about using ss washers to raise the clip up for clearance.
Thanks.
Thanks.
It mounts into a piece of plastic. I ended up getting longer self tapping screws from Home Depot and used those. I also recently replaced the washers with nylon spacers I got from Home Depot as well and cut to fit my needs.
Ahh, perfecto, perfecto. I have my curt adapter and flat-5 set here, awaiting the triple bar to arrive (and a warm dry day) to do my install.
Installed my OPT7 triple LED light bar, today. Here's a few pics of where I mounted my clips for the tailgate to clear the light when opening and a couple of pics with the reverse lights on and off from my back-up camera. Thanks to the many members that have posted pics and given excellent info on the install of this light to new gen Rams. A couple of tips: ensure that the bottom of the light bar lines up with the top of the bumper cover (lesson I learned the hard way), and I used 1 inch long speaker mounting screws on the included clips with a c-clip fastener on the back of the plastic for stability. For a spacer , I used a 1/4" hard plastic spacer from a tv wall-mount kit I had leftover. I always keep extra stuff like this for a reason! lol Hope this helps others on this forum.before rev.JPGwith reverse.JPGSAM_0822_LI.jpgSAM_0823.JPGSAM_0824.JPGSAM_0821.JPG
Yesterday I did the physical mounting of the OPT7 triple LED light bar and fiddled around with the positioning to get it clear of the tailgate opening, which is no small challenge.
In my case I mounted the 4 clips on the plastic fascia panel, spaced equidistant across the panel with spacers under each. I used 1" self-tapping screws on the outside and bolts/wingnuts on the inner clips. I may go back and use bolts/wingnuts on the outside clips for better strength. The one factor to deal with is that the fascia panel is curved - probably 1/2" farther away from the bumper in the center and closer on the outsides, which means thicker/taller spacers in the center vs. the outside edges, depending on where you place the clips.
I trial fit a number of times and tested the tailgate and found it touching every time until I decreased the spacer thickness and ended up with rubber washers as spacers on the outsides, about 1/8 inch (and probably compressed to somewhat less than this) and 3/8 in the middle spots. I'll check with a straight edge to see how close to flat the bar is, but there is some flex possible when it is mounted. There's also molded "bumps" on the very outsides of the fascia panel that keep you from mounting the bar flush directly on the fascia. When the bottom light row is about flush with the level of the bumper and the clip spacers are short enough, the tailgate clears with a few millimeters to spare. There is very little room (tolerance) to show well out back and miss the tailgate lip when opening, but it does fit and looks great when you get it positioned right. Hopefully 4 clips are sufficient to keep the bar from coming loose, but maybe I will figure out some invisible way to zip tie the thing as a fail-safe.
I have to zip tie up all the harness this evening...
But a question for @grinch72 (maybe I don't understand something): Why did you make that little 6 inch harness from both ends of the Hopkins 5-way kit? It seems like the light bar plugs right into the Curt 56584 5-way and you could just put a bullet connector on the white (reverse) wire and stick it into the one remaining open one (reverse) in the Curt? I am not sure why you made that adapter other than removing the bar with the single bullet connector wire might be fragile and fiddly if you had do it more than a time or two, therefore the 5-wire to 5-wire quick disconnect. Thanks for any explanations.
Not understanding the 6-inch harness functionality, I have just plugged the 4-wire plug directly into the Curt 56584. I sacrificed the unused OPT7 "hardwire adapter" 4-wire pigtail from the kit and used razor knife to cut one bullet-plug worth of connector with one wire off the molded 4-wire plug, then spliced that onto the bar's white bare wire and plugged that into the remaining Curt 56584 socket. All works fine.
I'll be sending the Hopkins 5-way plug set back to Amazon.
PS - I took a look at the light bar at night - quite cool. The backup lights make a huge difference lighting up the invisible area behind the truck. The OPT7 bar does not come on if you quick tap the brake, it needs about 1 second to light up.
Thanks for sharing all the info to put this together.
