Surroundview camera
I appreciate the feedback, Limited on resources here in Australia was hoping to have some luck from here.
You said black screen, completely black or part only? How the dealer can even try to calibrate, having the black screen, or they have replaced CVPM? Once CVPM was calibrated, it doesn't need to be re-calibrated. Either camera is gone or CVPM itself, may be fuse. Read this thread, You will understand how the system works. If You can't find good dealer in Australia, fix it by Yourself. System is not complicated, calibration is tricky. Not all of us were able to calibrate from the first attempt.
Somehow You had before working 360 view even with the lift.
Hi @Jimmy07, the same topic about adding 360 camera on a 2020 ram 1500
Laramie sport , i got a cvpm and i dont know how to find harnessesea to connect to it to give power,
This is the model of the cvpm: 68526184AC.
It should have 5 input but it has only 4 , then i guess signal will go from the harnesses (power + camera signal)
can you lend a hand out here when u r free ?with thanks ?
Also the cable u can make , does it connect to radio console ans also camera feedback
He can give it to you. Did you follow the how to guide on this? It gives you all the information.
I bought everything locally and pull thing that i can find. Cameras , fakra cables , and a cvpm unit
, the unit i got has only 4 camera input . Nothing out , i believe the outout would be together with the input connectors to power up the cvpm
I also change my radio from a 8.4” uConnect 4.0 to 12.1 Uconnect 5.0 .
So what missing now is a cable between the radio console and this cvpm. @Jimmy07 if u can make it , then u will buy it . Thanks
That CVPM is for the trailer surround view camera system, not for the truck surround view.
Well noted . Hence , the only cvpm would works for 360 camera is : 56029964AF .
Not any of the others : 56029968AF…
