I use it all the time as well. It is certainly a luxury and not entirely necessary, but I would not want a truck without it after having it. I do agree that it would be nice if it could fill more of the screen. I think the ideal scenario for me would be having the overhead view in one half and either the forward or rear facing cameras full screen on the other half.I use it all the time I just wish it was a larger image. 12" screen and the image is only about 3 by 2
I agree. I have a fairly shallow garage and have about 3 inches clearance over the length of truck. With the front camera I can go right up to the wall and leave about 1 inch. I know I could just use the good ol tennis ball method but I am REALLY glad that I can see the wall instead. Also, the parking garage at work has some tight corners so it is nice to see the clearance all around.I’ll go ahead and say that 48 hours after owning this truck, I think the surround camera is a game changer. At first it kind of confused me, but after parking this truck probably a dozen times now, it’s a necessity in my book. Very helpful in my garage and in parking lots.
How are you able to use it when parking forward? Mine doesn't come up when I park forward, only when I put the truck in reverse. Is there a setting somewhere?I use mine when parking forward in a spot especially when near a curb. I have the shortcut on my menu so I must select the app when starting to park. The overhead view is very useful.
Yes, tap the surround view I-con in the apps section on the screen and there will be 5 camera options appear to choose fromHow are you able to use it when parking forward? Mine doesn't come up when I park forward, only when I put the truck in reverse. Is there a setting somewhere?
Better yet, replace the default rear camera icon at the bottom of your screen with that surround view version...much better to have that one saved!Yes, tap the surround view I-con in the apps section on the screen and there will be 5 camera options appear to choose from
Same situation in my garage; the truck fits but there's not much margin for error. The front parking sensors turn red when I'm still a foot away from the back wall and my rear bumper hasn't yet cleared the garage door. The front camera helps a lot but I went one better: I tacked a pool noodle to my garage wall at bumper height. My original plan was to stick a flag in it (one tall enough to see over the hood) so that when the bumper nudged the noodle the flag would wiggle. I found that I didn't need the flag. The geometry of the camera angle works out perfectly such that my bumper kisses the noodle when the front camera view shows the edge of the noodle at the bottom of the screen. Go a bit farther and you can see the noodle start to compress. Perfect parking every time!I have a fairly shallow garage and have about 3 inches clearance over the length of truck. With the front camera I can go right up to the wall and leave about 1 inch. I know I could just use the good ol tennis ball method but I am REALLY glad that I can see the wall instead.
Yep, exactly where it has been since I’ve had the truckBetter yet, replace the default rear camera icon at the bottom of your screen with that surround view version...much better to have that one saved!
I've found that the striped regions on the overhead view are remarkably accurate at showing where the front and rear edges of the bumpers are. The corners should be accurate as well, though they're probably a little more conservative as the bumpers have a bit of curve to them while the striped region is squared off. I haven't had to angle park against a wall yet, but if I did I'd pull ahead until the corner of the striped region just barely touched the wall. (Well, the first time I did it I'd stop a bit short so I could get out and check my clearance, but I'd expect "corner brushes wall" to equate to "bumper within 2 inches of wall.")I [...] was wondering if anyone had any good tips on how to best see the corners of the truck with the cameras? I feel like that's the weak spot on the 360 camera system.
I absolutely love the 360 camera but was wondering if anyone had any good tips on how to best see the corners of the truck with the cameras? I feel like that's the weak spot on the 360 camera system.
Two examples:
1. When I back out of my garage at home I have to cut the wheel all the way once clear but I can't tell with the cameras and the striped area on the 360 view where my corner is in relation to the edge of the garage door opening. Now I am trying to get far closer than the radar is comfortable with but that's a whole other issue.
2. At work our new garage has angles spaces. Pulling into a straight space with the front camera is the best thing ever but pulling into an angled space against a concrete wall is a crapshoot since you really can't tell how far the corner of your truck is from the wall. I'm getting better but still have to occasionally move it again after shutting it down. I'm basically looking for perfection out of the camera system so I'm ready to be disappointed.
That’s what your blind spot radar is for!Update:
The corners are not weak on the 360 camera, they are non-existent. I put it in R and had my wife stand at the RF corner, not even touching the truck. She was invisible on the 360 camera and the front camera. Switching to the panoramic F cam let me just barely see her hand but if I wasn't looking for it I wouldn't have seen it. I then had her start walking to the R of the truck and she had to get more than a foot away from the truck to be just visible outside of the striped area on the display.
At least this told me that while I love the 360 camera and wouldn't buy a truck without it, I can't rely on it for corner maneuvering. The white/black striped boxes on the display are clearly there to tell you not to rely on the camera for anything in those zones. I am a bit shocked that the "dead zone" in the 360 view is that large though.
I encourage everyone to try something similar so you can see how much dead zone you have between what's really there and what shows up on camera.
All kidding aside, you’d need cameras in place of your corner parking sensors to see 100% coverage. As it is, those wide-angle cameras in the mirrors do an amazing job catching as much as they do.
