Sunroof Lubrication
I absolutely love my sunroof and use it almost every day on my way to work, I think we have had 4 new cars with sunroofs and two convertibles, not have really given me any issues.
Just an update: I got the truck back from the dealer, and they rushed on the job....:confused:
When installing the B pillar trim on the driver's side, they covered up the seat belt...so that was comical, they fixed that before I could leave.
So the next day, I notice the sunshade is very floppy, took me a bit but I figured out it was not in the guides, took me some time but I was actually able to fix it.
The next thing I notice is that the rear portion seems loose/not very tight, could not quite figure out if it was me just imagining it, then I found two bolts in the cup holder......so I think they forgot to install the rear bolts.
Also, the glass alignment is not great, not horrible but it could be better and now I see how it is installed, I think I can easily adjust it.
Very interesting turn of events for sure. At this point, I may never open the sunroof again! :ROFLMAO:
Rushing a job is no excuse for those mistakes. That's just a tech that doesn't care. Mine works flawlessly, and only "issue" I had was some dusty finger prints on headliner that were easily cleaned with a microfiber
How long is too long for a sunroof to close or open? Is there an acceptable range? Mine takes about 7-8 seconds and it just seemed like it was more lethargic than when the truck was new. Its a little better now that I lubricated the tracks. I first used some lithium spray grease but found better results with some Lucas spray gun oil I had.
Today I stopped by the dealer and got an appointment for them to look at this and the rear window TSB.
In all honesty, I’d rather not have the dealership dismantle my truck for a repair if I don’t absolutely have to.
Apparently 6 months is too long. Opened it last night and it was lethargic at best then wouldn't close on is own. Thing worked fine last fall.
Do you have to pull the headliner to grease the rear?
Sent from my SM-S931U1 using Tapatalk
I still have not found anything on these sunroofs in regards to grease. The main issue is getting access to the rear tracks and worm gear. The only way I can see to get access, is to remove the rear section of the glass. Which doesnt look that hard to do. I may attemp later this year, as the dealer left a bolt or a nut in the drainage tray and I have an annoying rattle.
I didn’t pull the headliner to lube the system, yet.
With the warmer spring temps, I’ve started using my sunroof more and it is like waking a beast from hibernation.
It's so hot in this Georgia sun that I don't open it. Y'all confirmed it. I won't open mine either.
