New to the forum, and picked up my 1500 LTD about a month ago. The sound system is just okay imo. 900 watts? I am guessing their rating is peak, not RMS. And we apparently do not have the specs as to how it is divided up. 900 watts divided by 19 speakers is only 47 watts each. Peak, not RMS. RMS would be much, much lower. Both are important but in different ways. RMS is essentially what we hear. On the other hand, exceeding the peak will cause clipping (distortion). Did they allocate more power to the sub? I would hope so. That then takes away from the power available to the rest of the speakers.
(And yes, I've fiddled with the Equalizer settings in the truck to no end.)
I took a quick look at the so-called 900 watt amp today (pull your driver's seat all the way forward and look under the back side to see it). I've seen 50 watt RMS amps larger than that thing. Perhaps a few less speakers and a bit more power to each, and especially to the sub, would have been more appropriate. But then, that wouldn't be as cool in the marketing flyers.
Having seen pics in this thread of the sub behind the rear seat, I am so far less than impressed. I'll look at mine in a week or two for first hand experience/impressions.
At this point, I'm hoping MTX comes out with a Thunderform for the 2019 RAM. I had one in my 2008 F150 and it whomped! It was a 12 inch sub with a built in 200 watt amp. If they come out with one for the '19 RAM, I will jump on it.
BTW, there was mention in this thread of various sources. SiriusXM compresses the heck out of their streams so that they can run a LOT of channels (streams) in their limited satellite spectrum. Even some talk shows sound horrible. Compression = less frequency response and lower dynamic range. I cringe every time I go from FM radio to Sirius. And FM radio is of course nowhere near as good as CD and other sources but does sound much better than Sirius. In addition, you will find many variations in streaming sources. I did try Pandora with my iPhone and USB connection to CarPlay in the RAM. I wasn't impressed. Have not tried Spotify or Amazon Music. Nor iHeart.
All of that said, I can live with the existing HK system for now but am looking forward to seeing if MTX comes out with a Thunderform for the '19. If not, I'll be visiting my local auto sound dealers to see what they can do to pump up the sound. Especially the bass.
