Is this for the sub only or is for adding an AMP too?I have the same set up and just installed the subwoofer harness with ANC bypass from Net Audio and was able to add subs with no issues.
Dodge Ram Subwoofer Install Subwoofer Harness Converter
dodge ram radio t-harness, dodge ram radio harness, dodge ram harness, dodge ram radio t-harness, dodge ram radio harness, dodge ram harnessnetaudio.com
Power for what exactly? If it’s an amp, then yes, the battery or the post on the engine bay fuse block that the battery cable terminates at.Hi guys… where or what color wire did you tap for power? Or did everyone run to the battery?
That is a diagnostic port used by the manufacture to get device info or change settings.BTW - what is the 4-pin port on the ride side of the ANC?
closeup
Thanks, I appreciate the response.That is a diagnostic port used by the manufacture to get device info or change settings.
Yup, run a dedicated wire that is made for amps. My amp is mounted under the drivers seat with the wire running under the plastic sill plate. It then goes through the firewall directly to the battery (with an inline fuse).
I am installing a sub and planning to use the high level inputs. what wire did you tap off of? did you use a single speaker signal wire to left and right on the amp?I have the same set up and just installed the subwoofer harness with ANC bypass from Net Audio and was able to add subs with no issues.
I’m assuming you are buying the bypass. If so, you could cut the speaker wires running to the PAC and use those for high level input. I ended up disconnecting the PAC all together and running all of the speaker wires from the harness to an LC7i. From that point I ran one amp for subs and another for 6x9’s. If you are looking to tap factory wires without bypass I believe…I am installing a sub and planning to use the high level inputs. what wire did you tap off of? did you use a single speaker signal wire to left and right on the amp?
