No, if you need a truck you need a truck. Personally, I need to haul a 6,000 pound trailer and - sorry - a corolla just isn't going to cut it.
If you already need a truck, and you're going to drive 14,000 miles a year, why would you get one that's inefficient? I could have bought a Toyota Tundra that gets 13/18mpg, and on my short day-to-day commute you can bet it would get 13mpg or worse. With eTorque, I get 17/23 - right about what the rating says it should get.
Even with gas at $2 a gallon, that difference day-to-day is over $500 a year. At $3.50/ gallon, that's over $2,100 every year. At current model prices, eTorque is going to pay for itself in just the first year. Over your miLliOn miLeS of driving, that's a whole new vehicle.
It's not like this is the 80's where every truck has some carbureted V8 that gets between 10 and 12 MPG. Hybrids, light hybrids, turbos, and diesels mean you can actually get 30+MPG in a full size truck, and if you somehow don't care about the money in your pocket, or aren't going to drive the truck much, who cares about comparing any metric? Just go get a Raptor or TRX and enjoy the insanity.
OP, I know you mentioned you don't do much towing, but it's also worth noting that diesels usually get the best towing mpg, followed by gas V8's, and then the turbos https://tfltruck.com/2018/06/mpg-challenge-most-efficient-truck-towing-listed-specs/
Except that the math doesn't work out like that. Before crunching numbers, you have to take into account:when your truck is only getting 13-15mpg city, a diesel that can bag 24-30 mpg city really starts looking great. for the gassers, take 30-40% off that if you tow. 10-15% for a diesel, and the diesel won't care even with 1/2 the HP.
normally the increased fuel mileage, powerband and longevity in a diesel made them no brainers. these days with all the complex emissions, proprietary maintenance items and questionable durability make it a tougher pill to swallow.
if I can find an open stretch of road I can drive between 55 and 62 mph I can get 50+mpg with my ecodiesel. it will reliably get 30mpg and 900+ miles on a tank. you can forget those numbers on a fullsize truck even a decade ago. maybe an old mazda b2200 diesel could come close. and it's a tiny thing with 60hp, being generous.
the big thing ram has going for it is the interior quality. especially the premium trims. take a look at a king ranch, or platinum ford or a high country or Denali Chevy/GM. then drive a Longhorn or a Limited and be prepared to be blown away.
1. Ecodiesel is a $3200 upgrade over standard Hemi;
2. Diesel costs 30 cents/gallon more than unleaded;
3. E-torque is a $200 upgrade over standard Hemi.
Ok, so with that out of the way,
Ecodiesel: 22 city/29 highway;
E-torque: 17/22;
Hemi: 15/21
Let's assume 12k miles per year, 30/70 split, or 3600/8400
Ecodiesel: 163 gallons/289 = 452 gallons @ $2.50/gallon = $1130
E-torque: 211 gallons/382 = 593 gallons @ $2.20/gallon = $1305
Hemi: 240 gallons/400 = 640 gallons @ $2.20/gallon = $1408
So you save $100/year with an E-torque and $300/year with an Ecodiesel. Raw payback (this means excluding all the crap they make you get to get these packages besides, just going engine to engine):
E-torque: 2 years (not bad)
Eco-Diesel: 11 years
So if you're really concerned about MPG and want a Ram, you get a modest payback with the E-torque. You just have to ask yourself if $100/year is worth the added complexity and cost of the system, not to mention the replacement cost - per another forum member the generator & battery cost are almost $3,000. If you have to replace them one time your payback is 30 years.
That's why I said I never really bothered to check my MPG. Once I was settled on Ram it didn't make any difference. A truck will burn up a lot of fuel regardless and efforts to mitigate that (like e-torque and diesel) cost a boatload of money. I'm all for better environmental efforts, and actually engineers developing stuff like this pushes the conventional stuff to do even better, but really at the end of the day your best bang for the buck with MPG is to have a little car that you use when you don't need a truck. Back in 2004/2005 when fuel prices went apeshit, I had a new Titan as did a lot of other guys (it just came out in 04). I could not convince those guys no way, no how that they would be better off just getting a beater to run around in and use the truck when you needed it/wanted it rather than dumping them at fire sale prices and taking a bath on the sale. And showed them that unless you drove a ridiculous amount of miles, even at $4/gallon it didn't make sense for most people to get another car because there wasn't enough driving for the less gas to compensate for the costs of getting another vehicle.
So me, for example, I always had a long commute so I kept an econobox that I could run into the ground that would get me 30+ MPG and saved the truck for weekends and working in my business - but I typically drove 50k miles or more in a year. I drove 4 econoboxes into the ground in 20 years, but these cars cost me peanuts compared with my Titan ($28k new in 2004) and my Ram ($37k in 2019). I was able to make the Titan last 15 years and I fully expect the Ram to do the same.
Anyway, that's my spiel
