Rough Country Grill Lights and Hidden bumper Light
CharlieP
Gentlemen: Just wanted to post some pics of my Rough Country Grill Lights and Hidden Bumper Light Install. I did the light install but took it to my Local Shop to do the wiring, mostly because I could not find switches that I liked and thought would look good in the dash. I am more then happy with the outcome
Looks good, what local shop did the wiring?
Looks good. Here’s mine
Installing mine now, the 6" grill lights. But noticed that when I am trying to take off the front / side bumper under the headlights that after I remove the 4 screws and then unsnap the fender flare / cover, the front bumper under headlights has a bolt in the wheel well. Was a little concerned about taking it out and getting it back in there. It was not in the instructions. Was curious if you guys had same issue or if something unique on mine. Did not see anyone talk about that bolt. Thoughts?IMG_3125-1.jpg
Installing mine now, the 6" grill lights. But noticed that when I am trying to take off the front / side bumper under the headlights that after I remove the 4 screws and then unsnap the fender flare / cover, the front bumper under headlights has a bolt in the wheel well. Was a little concerned about taking it out and getting it back in there. It was not in the instructions. Was curious if you guys had same issue or if something unique on mine. Did not see anyone talk about that bolt. Thoughts?View attachment 37285
Yes That Bolt is a pain in the *** and is not mentioned in the instructions you have to remove it or you will tear that front cover
Just wanted to say your switch placement is super clean and I will probably place my switches there for my rough country grill lights. Do you have a diagram for how you wired the switch to always stay lit?
Might be a stupid question, but does the lower grill light output get diminished some by shining through the grill?
Thinking of doing this to mine, but my trucks lower grill is solid, id have to get a " mesh " one. Debating wether or not its worth doing if it doesn't give that much more light. The led headlights and fogs are amazing though.
The switch is only lit when the lights are on. the only light that is wired not through the switch is the DRL on the hidden grill light
Yes you will need the mesh grill. if the light is diminished any it is very little
What do you think about cutting a slot in the solid grill big enough for the lightbar?
It will still be sitting back behind the grill so you will have that gap that will be seen. Maybe try it with the solid grill and if you dont like it then order the open mesh.
Rough Country has a link to the mopar grill for the light bar. It's like $34 or something. If your not really reading the description down below..you can miss it.
