Haven’t really thought about that. The mount I have designed is specific to 20” rigid industries light bars, is that what you’d be putting on?Thanks for the info did you think of making them and how much of corurse shipping would be xtra
Why I miss my old job, I got to draw the parts, machine them on a Mazak, Milltronics, or Quickmill depending the size and then weld them up.You give me an autocad program, some cnc machines, and a welder and I can pump out whatever you want....Anything else computer related is way over my head.
Great install, just one problem
I just hope you do not get it trouble with the law as most states do not let you drive on major roads with your off road lights on,
I would recommend you install a switch to turn them on and off, not having them tied into you bright lights
Making them is easy for me, but the logistics would be the hard part.I second the build and offer them for sale. You might be surprised how many people might want them. Nice job.
I wired it to the battery using a relay. In your case I’d recommend using a relay as well, 20 amps is a lot of power. You could find an ignition power source in the fuse panel and use that to activate the relay, safe and easy.Where did you pull power from?
I need to find 20 amps (switched) for my 2-way radio...
Yep, there’s enough room. Where my light bar is placed started out as a faux grille, no air passes through there. So you will have to remove the plastic cover that’s on the inside of the bumper, it’s held on with 20 or so plastic clips that are fairly easy to remove (just work from one side to the other) and if you’re capable of making some custom brackets it should work pretty well. From the looks of your render I might have to add some myself!This looks great! I'm planning on doing the same thing but the behind grill, cheaper RC version: https://www.roughcountry.com/ram-led-bumper-kit-70779c.html
In addition I'd like to do 2" square lights on the far ends of the grill (outside of the sensors, pictured). Based on your experience do you think the 2" square lights would work there?
Thanks in advance,
Leif
PS I could’ve left my grille but decided to cut it for max light output (and it’s only a $26 piece if I change my mind)
I'm pretty sure it's 68414138AA I've seen it as low as $20 on some websites.Do you happen to have the part number for the grille piece?
Yes, there's room but you have to remember there's plugs coming out of the back of the parking sensor. So for a longer light bar to fit it would have to be set back into the truck further so it doesn't interfere with the plugs or wiring.Do you think you could put a longer light bar behind that grill and behind the park sensors if you didn’t care about it being behind the grill? I have a 30” Baja designs onyx6+ I am taking off my Silverado and don’t want it to go to waste with my new truck!
thats what i figured. i wonder how many inches of space there is behind the plugs until i would run into an issueYes, there's room but you have to remember there's plugs coming out of the back of the parking sensor. So for a longer light bar to fit it would have to be set back into the truck further so it doesn't interfere with the plugs or wiring.
There’s plenty of space behind the plugs, but because of the plugs you’d have to keep it back about 2” behind the plastic grill. But aside from that there’s enough room.thats what i figured. i wonder how many inches of space there is behind the plugs until i would run into an issue
