Chris3058
Welcome aboard. Lol
Hopefully you have better luck with just a battery replacement as most who have had their batteries replaced, it didn't fix the problem.View attachment 117882 View attachment 117882 Guess this explains my remote start issue. This is after an hour on the highway. Guess the battery is toast?
Good to hear it’s working. I haven’t had any issues since the update either.Started again today at -26°C. Whatever flash update they did seems to have fixed the issue with my ecodiesel.
It’s going in next week - again - and I’ll mention the new update / sensor that JC talked about. We shall see.Hopefully you have better luck with just a battery replacement as most who have had their batteries replaced, it didn't fix the problem.
Mine indicated the same the morning after a new battery was installed and it was cold out.View attachment 117882 View attachment 117882 Guess this explains my remote start issue. This is after an hour on the highway. Guess the battery is toast?
From my book of lessons learned, new does not imply good, it only implies expected good.Mine indicated the same the morning after a new battery was installed and it was cold out.
That is true, however when I put a heater blanket on it, it has started every morning when it's cold out. And the previous battery tested fine and they only put a new battery on it because I complained that it was doing the exact same thing after they tested it.From my book of lessons learned, new does not imply good, it only implies expected good.
How true is that!!! Nailed it.From my book of lessons learned, new does not imply good, it only implies expected good.
