Too bad you don't know the BCM version. Is it possible to call the dealer to find out? This is what I found online.-10C this morning and remote start worked once again. Starting to have a bit of confidence in the newest bcm update.
If there is an update, please let us know what firmware version it is so that we can have it applied to ours. Thanks.Taking mine in for this. My truck had these issues last year and they replaced the battery and it fixed it for a while. Now that it's cold again it's doing it again..kind of annoying. Hopefully they apply that update.
Will do. They want me to leave the truck overnight..knowing my luck it will fire right up.If there is an update, please let us know what firmware version it is so that we can have it applied to ours. Thanks.
They will probably leave it inside overnight and of course it's going to fire right up. If they leave it outside and when the truck attempts to start after the first horn the battery will measure around 11.9V and the ECU will cancel the remote start thinking that the battery is dead when in actuality it has just lost capacity due to the battery being cold.Will do. They want me to leave the truck overnight..knowing my luck it will fire right up.
I want them to do the update anyways and will push for it. It's annoying not having remote start in these Canadian winters.
If the lithium batteries weren't so darn expensive, I would try one as they don't lose nearly the capacity that the lead acid ones do when exposed to the cold.Will do. They want me to leave the truck overnight..knowing my luck it will fire right up.
Good to know. I'm going to push for it. I'm sick or my 90k truck not starting because it's cold.-10C again this morning and the remote start worked. Tonight is forecasted to be -15C. Seems the latest bcm update did the trick.
Your problem is totally different than ours. Hope you find a solution.I want to chime in on this thread. 2022 Big Horn with E-Torque, Brand new, have had it since December. Noticed one cold morning it would start and then it was struggling to stay running. Didn't think much of it, thought it was a fluke, but it has since done it a few more times. It will actually start and then struggle to stay running on super cold mornings. It has only one time totally stalled out, when that happened the "Battery" light on the dash was illuminated.
Haven't been to the dealer yet but just wanted to get in on this thread. Hoping we find a fix!
I know that ever since I put a battery warmer on my truck, it has started every morning even at temperatures down to 0 degrees f. Don't know what the dealer will be able to do for you if engineering doesn't change the firmware of the BCM to lower the threshold voltage of the battery monitor.Well day 6 with my new battery and low and behold it stopped working again. Was about 15° so my truck said once it started. Cold yes but to affect a brand new battery that fast? Seems a little bit odd. There has to be some kind of software update that I'm missing. Because the truck starts fine pushing the button no hesitation and cranking over. I guess it's back to the dealer I go while I still have warranty
And meanwhile here it was about -10 Celsius in mine decided not to work. I didn't even get the two beeps this morning from the horn. Straight to a single beep. I decided to grab my tester just to see what the battery voltage was at before I started it. Said the battery was at 11.75 v. Proceeded to start the truck after myself and it started with no hesitation at all.-15C again today and remote start worked fine.
Reverse camera on the other hand isn’t work and all I get is a black screen when trying to view it.
Mention it to your dealer, I just had another bcm update done that is supposed to resolve this issue and so far it seems to be working. Before the update I’d be lucky if remote start worked at 0C.And meanwhile here it was about -10 Celsius in mine decided not to work. I didn't even get the two beeps this morning from the horn. Straight to a single beep. I decided to grab my tester just to see what the battery voltage was at before I started it. Said the battery was at 11.75 v. Proceeded to start the truck after myself and it started with no hesitation at all.
I was actually talking to him on Thursday because it failed once last week. And I asked about the software update. He claims I have the latest and greatest but he's going to dig deeper. In the meantime I'm just dealing and seeing how it reacts day to day. So after I started it normally today let it warm up get everything up to temperature. Went for a drive into town to do a couple errands. Got them done came home. 2 hours later to go and take my son to work. It was already failing within a matter of 2 hours. Makes absolutely no sense. You would have think it would have been charged up if it was the battery issueMention it to your dealer, I just had another bcm update done that is supposed to resolve this issue and so far it seems to be working. Before the update I’d be lucky if remote start worked at 0C.
