Joeyp
I gave up and bought a new streetbike
I emailed them the other day about buying the 4” lift around June and they replied it should be out if all goes as planned by then.I am sure, lot of people are desperately waiting for the BDS lift kit as I am, but just wondering if anyone heard recent news or something.
The nature of adding bigger tires is having reduced power. Depends on what you consider sluggish. I run 35x12.5 with a 3.21 and it runs fine to meHave some one tried the 4” BDS kit in a 2019 ram 1500 limited with air ride? If so, with 35X12.5R22 runs ok? No vibration nor sluggish ride? What about MPG change? Thanks!
You would notice a big difference with the 3.92...especially with the 35'sThe nature of adding bigger tires is having reduced power. Depends on what you consider sluggish. I run 35x12.5 with a 3.21 and it runs fine to me
Thank you SColang22, that is what I wanted to read, I also have a ram truck but with an air suspension so I was wondering if it was good idea to lift it with the BDS suspension 4", I also have a gear ratio of 3.92. Thanks again!The nature of adding bigger tires is having reduced power. Depends on what you consider sluggish. I run 35x12.5 with a 3.21 and it runs fine to me
I wouldn’t say it’s a bad decision.Thank you SColang22, that is what I wanted to read, I also have a ram truck but with an air suspension so I was wondering if it was good idea to lift it with the BDS suspension 4", I also have a gear ratio of 3.92. Thanks again!
ive had both and really it’s not much differentYou would notice a big difference with the 3.92...especially with the 35's
Thank you much!I wouldn’t say it’s a bad decision.
