Recon LED Projector Headlights
These are the "smoked" ones. No need for tint in my opinion. I also saw the spider ones. Only thing I wasn't convinced of was the OLED. It is white. I saw some reviews that Said it looks pink when on during the day.
Looking them up now. I see what you mean. The recon ones are like a cherry red and reflective, compared to the spider ones.
How do they look at night?
To be honest, I know I'm spending a little more on recon ones compared if I decided to go with the factory ones. That's why I didn't get the led package, because I wanted to get my own set that I like.
2016 Dodge Charger scat pack and my wife 2021 Jeep Wrangler Unlimited Sahara (2.5" rc lift with 35" duratracs)
have a night shot? I wanted them, figured I was better off putting the money aside for some new tires tho haha
Here are some night shots. I want to keep the stock wheels and add a leveling kit with some ko2 tires. But will have to wait a while. Funds are also running a bit low. Lol!
I think they look really good with the tint, goes with the grill. I wish I could’ve gotten the painted bumpers and grill but was able to get a pretty good deal on this bighorn with the chrome. I ordered the Tazer module once it comes I’ll see if it fixes the drl thing, I keep forgetting to shut the lights off now lol did you upgrade the fog lights?
So did you get the JL Tazer and change the DRL and did it work? I just put the Recon headlights and taillights on my wifes truck and if that is the fix I will do it when I have my buddy who has an OBD flash my truck to turn on the passive entry. As far as fog lights I got some from LASFIT which is just changing the bulb but they are really nice.
It sounds like they're functioning as designed. The "DRL" strips seem like they're more of a parking light / running light, not a DRL. Activating your DRLs in your Uconnect is doing what your truck is currently programmed to do, run the low beams at half power. Without modifying the wiring, you're likely stuck with that setup. Or, you could go to the dealer and have them reprogram your trucks BCM to have the DRLs be switched to the parking lamps, which should then cause your DRL strips to come on when the truck is in drive / on.
Would this make the DRLs in the Recon taillights work like the headlights would if you get the dealer to do this? I just bought my headlights and taillights not too long ago and this is my exact same situation the DRLs don't work. Just the low beam comes on.
DId you have the factory halogen or LED lights when you got the truck?
I had factory halogen
That's probably why they're not working. Your truck didn't come stock with the factory DRL strips. I'm almost sure the wiring for the halogen headlights vs the LED headlights is different from the factory. You'll have to wire in the DRLs another way if you're wanting them to come on.
But if i get the dealer to reprogram the drls to the parking lights shouldn't that work?
just curious...do these recons self-level, and "look" around corners like the factory ones on my Limited?
Other aftermarket headlights like Alpharex have a separate wire that is tapped into fuse F38 for the DRL signal and another wire that goes straight to the battery for power
Dealer cannot do this. There are actually 2 wires missing from the BCM to the lights. The only way is a adapter harness and AlfaOBD or the Tazer.
So what exactly do I have to do? Do I need to mess with wiring or is there a way around that? Not looking to spend a ton of money just to get the supposed DRLs to work
Jimmy07 makes an adapter harness for that conversion, very easy to install. It just plugs in between the OEM plugs and the lights. 2 wires needs to be run thru the fire wall and plugs in the BCM
Ok so that's just for the headlights right? And how can I get said harness?
That's for the OEM head lights, correct. To install the LED tail lights, they are plug and play with one setting changed in the BCM.
Search for @Jimmy07 here on the forum and PM him, he'll take care of you.
I installed aftermarket led headlights with DRLs on my halogen setup. Everything was plug and play. You just have to make sure the led headlights you purchased are replacements for halogen setups. The way to tell would be an extra wire/cable with a fuse end that needs to be plugged into the fuse box. Scram1500 mentioned the slot number where the fuse need to be plugged in for the DRLs to work. Once everything is plugged in, make sure in your headlight settings that the daytime running lights are turned off. Having it on will run your lowbeams. Having it off will run the led strip DRLs only
