Recall of High Pressure Fuel Pump
More updates. Fuel pump was replaced but the CEL is still on. They are doing more diagnostics tomorrow but mentioned if they don’t solve it tomorrow then they will need to work with the Chrysler “star” engineers to see what they will replace next. (Could take weeks)
They looked more into the oil leak I pointed out and they feel at some point the oil was over filled during an oil change. Possibly a few times. They suggested that since the dipstick sucks so much that I should allow the oil to drain for at least 30min and if possible even more. They say it takes long for all the oil to drain and it’s easy to overfill. If it’s overfilled, it would build excess crankcase pressure and potentially cause a leak there. If the turbo was failing and leaking oil they would expect other codes and the truck would be constantly doing regens which they say isn’t the case. We will see what’s next. It sounded like they aren’t authorized to just replace the fuel system and injectors if the fuel pump didn’t fail with the recall. That’s where the “star” engineers need to approve.
Agree, but trust me other brands are no better.
Go read other forums and see, maybe if you are into the luxury stuff.
When I owned a BMW they were amazing for service.
BMW service is top notch. The key is $$ lol. We were fortunate enough to be offered an additional 40k mile maintenance plan on our x3m comp for $900 (1.5yr or 75k) The deal was too good to be true but so far it’s awesome. Top notch rentals and it’s nice to know the car is getting what I needs. They send us detailed videos of inspections and even invited me to go review the underside and all the details if I wanted to….which I did. I was impressed.
My ram dealer was initially not giving me a good taste but the issue was miscommunication and they had confused my truck with someone else’s. Once we straightened that out it’s actually been really good. My advisor seems to be very transparent and not BS’ing anything currently.
My Toyota dealer also is top notch service. They send a video while they are working on it to show them diagnosing the problem and then a video after the repair is done explaining the entire procedure. The videos show the actual mechanic that is doing the work.
Tom
Tom
One of my son's did this working on Audi's, now he does it at the RAM dealership he's at and people love it.
Is there still a Ram rep or dealer rep that reads these forums that can help?
I can’t get anywhere with getting the fuel pump warranty replacement done on my 2020 ecodiesel. We bought it because with the right rear axles and airbag suspension, the tow capacity approaches some 3/4 ton, but now I fear the truck is going to blow up on me.
I live in northern NM and the closest dealer in Espanola NM just went out of business. I had an appt scheduled there to get the process started but they suddenly closed up shop 2 weeks before the appt. I have been on the “waitlist” at a dealer in Santa Fe (Lithia) but after months of waiting I called and they seemed to not know of any waitlist and are just saying they can’t get parts and won’t schedule the appointment?
Any tips or advice to get through this blockade?
Had my high pressure fuel pump replaced yesterday and got the “piece of mind” inspection done for $89, my truck has 99,000km, powertrain warranty runs out at 100,000 km. All was good except the rear brake pads are almost down to steel on steel, which I knew, front rotors are corroded but the pads are at about 50%.
They put a pamphlet in the truck stating that the fuel filter must be replaced at every engine oil change instead of every second oil change.
To my surprise they did an engine oil and filter change by mistake and did not charge me for it, saved myself over $250, my oil was at 50%, 8,000km (5,000 miles) We just came back from a month in Florida towing a small travel trailer.
I have been putting 1 oz of Hot Shot EDT diesel additive at every fill up. Before my trip home from Florida I added 8 oz of Hot Shot Diesel Extreme for a good clean up.
I always do my own oil changes after the warranty runs out. I also do most of the maintenance like brakes, suspension parts….
I was hesitant to buy oil filters from Amazon. Fram (Fram Extra Guard CH12939) is finally making oil filters for the Ecodiesel for less than 1/3 of the cost of OEM.
It's funny, my dealer said nothing about more frequent fuel filter changes. None of the documentation mentioned it either.
Tom
Tom
Here’s the pictures of the pamphlet and also a note about the biodiesel use
Next to a chicom fake, fram is probably the worst filter you can run.
I have been using Fram filters since 1994 on 3 dodge caravan, my 1994 Caravan I had for 13 years with 300,000km , 1 Dodge Caliber, 1 Hyundai Accent, 2 Ram trucks, my 1996 I had for 15 years, my 2011 I had for 9 years, never had engine issues now I will be using the Fram filter for the first time in my Diesel Rebel for the next oil change.
Opinions matter but proof of use is better.
Nothing wrong with Fram filters. Are they the best? Probably not, but they filter oil just fine. Can you find better filters? Yeah, but you don’t need to.
Got my truck back and it definitely feels much better compared to when I dropped it off. They replaced the fuel pump and the entire fuel system (injectors, rails and all). They weren’t originally going to do that as the truck came in running so they’re only authorized to replace the pump. As I had the p026 code and it seemed to be tied to an injector they went ahead and replaced it all. Looks like they did a good job. Clean engine bay, no missing fasteners and everything is routed as it was. Took them a while but the dealer was giving me updates throughout, I must say I was impressed with their service and whoever their diesel tech is he seems good. Truck is much quieter and already I’m seeing better fuel economy just based on the mpg gauge. Also they stated, 2yr unlimited mileage warranty on everything they just replaced. Was going to tune and maybe diet but now with that warranty on 10k worth of parts and labor….maybe not.
Finally got my pump replaced. Dropped off at 9 and picked back up around 3 the same day. Service advisor told me they've only seen 1 vehicle that required the entire full system (including all lines) to be replaced. Said it was a $90,000 wrangler that had been in the shop for 4 months because they cant get the fuel lines in. What a disaster! So far I notice no differences in the drivability of the truck. Just happy to have some piece of mind.
Finally got my truck done. In and out in about 4 hours. The Rep said there was zero evidence of contamination so they just replaced the pump. I got the same pamphlet shown above and it recommends a new fuel filter when you get the oil changed. Oh well. My ED is a August 2020 truck and I only have about 36,000 miles on it.
I didn't get any pamphlet. I think I just have some of the worst DJRC dealerships around me and they don't care about anything. I've been replacing my fuel filter every other oil change with no issues.
So since most owners don't follow the correct maintenance procedures (draining water periodically, staying up on filter changes, etc.) they've gone to requiring a new filter every oil change (which should be happening BEFORE 10,000 miles per the manual)?? Wow... that's going to get pricey. The oil changes are already pricey on the EcoD, now it just got worse.
I change my oil/oil filter at 5K intervals, with new fuel filter every other oil change, nominally 10K. Would this maintenance schedule satisfy the new requirement?
Every other oil change is fine. VM Motori (manufacturer of the motor) recommends replacing the fuel filter every 30K miles or 36 months. Dealers are trying to give you a reason to pay them more money.
Not really, oil changes aren't that expensive. A ton of aftermarket filters now for $20-30 and oil is cheap.
I'll keep replacing my fuel filters every other change. My truck is out of warranty anyways
146,000km and zero issues.
Sent from my SM-S911W using Tapatalk
