Rebels with Nerfbars/sidesteps
I was able to get new pics today to show the Westin Pro-traxx 5.
Rocky Road sliders.
Some idiot tested them today in the hardware store parking lot...
Her Rogue has a VERY nice dent in the edge of the door where she flung it open into the side of my truck... Rogue 0 Ram 1
No damage to my truck the slider took the hit.
Mine came off the lot with the factory black running boards, I absolutely HATED them as they hang very low and don't really match the style of the Rebel. I ended up slapping on set of Go Rhino Dominator D6 steps and I couldn't be happier! They sit much higher so they won't get in the way while playing off-road, and I personally think the style is much better suited to the Rebel aesthetics. If you like the style of these but want a version that's not as wide, Go Rhino also sells a set called the Dominator DSS. They're nearly identical to the Dominator D6, but about 50% narrower.
Factory Running Boards:
Go Rhino Dominator D6:
I made the mistake of ordering factory too. I knew I wanted them seemed like a no brainer. Do not buy one that has sidesteps from the manufacturer if you can
Rocky Road sliders.
View attachment 139986View attachment 139987
Very nice, how do those seem quality wise?
They feel like they'll be able to slide and support your truck?
Sent from my Pixel 5 using Tapatalk
Yes they will support the weight of the vehicle.
I jacked the truck up with my hi-lift (with tube adapter) when I installed them to see.
I ran a trail last weekend that I bottomed out the drivers side on a rock in a sharp turn and drug along for about 9 inches. powdercoat is gone there now... lol
Go Rhino Dominator Xtreme DSS Side Steps with custom step extensions.
I really like the design and that the mounting brackets do not hang below the rails. These definitely are not sliders, but they are reasonably heavy duty and may be able to absorb a sacrificial hit and protect the cab from damage.
As mentioned earlier in this thread, as delivered, these DSS are not an effective step. They are alright for stepping in, but the rail is too tight to the body to be used as a step when getting out. To address this I designed some custom bolt-on extensions. I am really happy with how they turned out. They now work great as a step both when getting in and getting out.
KxPmp5CGK6pHVEKHKhfa-i0YaHTPooQ1kzK-7uwYEUHKqFDNwl4MYHNVitFWREIVdzp5emAlEPWNM-8VGfwIm9sHoRkpPYTBq574u4X70TFIBUnaO-MZn0LlD5OfC5gRaWjaS9awFM11WbDEmVrM2LtkxZqWHKa9aphwoE5GFhgA0AKAK2JEkiuKzQ
u9N_-bwgAl-yJkdfMIr4Hvk8KGzVDxqvq3JMeN8DVkwhDE2HIbvtMN4o9i0W6qL6ga2bM1e8n8Qmkeqlo6YRuZbbaF1o6xAXSflAGNsmLdsinoSSol_rf2_f8gYRwviCCPxZ7uu2BJ4p3c76K1dDDoIA5DF2JYnNhWO-AnSI2pCjcOjejnhXu5MVwA
IXrdL7qgf8pEyDknlzI5UPlcfQWUlNOpxFscysxuGLTMhdZMTMV9h9I5rxDzfJlxTeiGULvJuq2qLA1lKNmDkzJATZGxUiJkmlS5YHVVs33QCZy0Ss2DEYjnoF_4_pzixjXObeuMXcdKGcBzpSCeq6MqTPcHS8pctQZ2_yLM8QFgRNtpqVtXzsQfQQ
I added nutserts on the front bar and have brackets that tie into the main c-channel on the back
TBeO6Y9ZvCbg471AQEkeTfAkNJcbw-ri6a0F80TW9Ed7kcnd76xseAx2oVcJYk1snCJNsmgAwlbeiB_vvPB4EoSSF3jLl2jYZIpOyj4gWsiX-Qdq1hhIHoJRluLZQIuOPxe4uWXTixcnrVK1PoNvH08hpeo6RBv8He-gpW3qB4SOTQJvRVGlMShy-g
Custom non-skid formula - grit plus spray paint.
UKpo3YH-T_LccJATwy4ksyo2BPs9PIkAKX40ugbZDsHMtZKl56A6kOOEDI6YswtwiK9793Iefcxs4nbwZUTLe9Hiy4toCt5DILcV9wqnn574EK8Iqe5Nmk1ndfYZT0zeQpe9DyJmPVUjNJuHmKkvfxRwtNnSsEEmnpLCLPDZ05jzrTXQ1-lVj_U5XQ
3/16 x 4" bar cut to shape and drilled to match the DSS top plate.
