Rebel vs Laramie Suspension
31RamIt
What are the differences? If I bought a long travel suspension kit that says it is Rebel specific, would it fit on the Laramie? Or, are their major differences to the suspension?
EXAMPLE
Im thinking shock/spring rate being different. Should bolt in just fine. Im sure others will chime in.
My understanding is that if the Laramie is equipped with the ORG, the only suspension difference between the Laramie and Rebel is the shocks.
So, that being said. Do you think a LT kit for a Rebel would bolt up?
You would do well to contact the manufacturer and see why it's listed for the Rebel only, but I'd be pretty confident that it would bolt up. They may have only tested their kit with a Rebel, and aren't aware of the similarities between Ram 1500 trim levels.
EXAMPLE
I have a Laramie and just redid all the suspension and tires etc. Rebel specific kits and ORG specific vehicle kits are in fact vehicle specific. Be highly critical of it all. Make sure it matches your rig 100%
