Just crazy man! Hopefully they get this problem dialed in. Other then that I love my truck.I think a few 2020 owners had cracks as well.
I don’t know if it helps anyone, but I finally had the rear window replaced on my 2020 Rebel (build date 10/2019). Part number for the window assembly they put in was 68426398-AC, description is BACKLITE 2. It looks like that part number replaced part number 68303352-AC. Also, FWIW, I’m pretty sure the new window had a sticker on it that said it was made in CN, not USA.
Sticker looked like this:
My 2020 Laramie (Build 7/19) is scheduled to go to the Dealership for replacement on Tuesday. I'll try and see what part# they put in. How long did they have your truck? I was told hopefully could be done in 2 but told me they need it for 3 days.I don’t know if it helps anyone, but I finally had the rear window replaced on my 2020 Rebel (build date 10/2019). Part number for the window assembly they put in was 68426398-AC, description is BACKLITE 2. It looks like that part number replaced part number 68303352-AC. Also, FWIW, I’m pretty sure the new window had a sticker on it that said it was made in CN, not USA.
That's the rear window that I got last month.Does the window appear any different?
It doesn't look any different other than there's no cracks in the frame, but the slider is quieter when I open/close it.
add me to the list. i have the same crack as everyone else (not talking about my a$$ crack either). mines a summer 2019 build, 2019 model. no leaks yet that im aware of, headliner is dry. going to just keep an eye on it, but i doubt itll stay dry forever. dreading taking it to a dealer
You could see the cracks in mine. The driver's one had been propagating for a bit so was noticeable and the passenger's side you could see a hairline in it unless you parked on an uneven surface then it was noticeable.Count me as another one with the problem. Thanks to this thread I just went and looked at mine. I have the crack on the drivers side of the sliding window and I can see some water spots on the glass. I’ll have to watch it and see if I can catch a picture of it leaking. Then I’ll take it in.
Has anyone had the crack and not had leaking problems? I’m just wondering if it‘s worth the trouble to have anything done, or if they would even do anything if it’s not leaking. I think I’ll watch mine, if it’s not leaking I’ll still let the dealer know so it’s on record.
It doesn't need to be leaking to take it in, it's cracked and shouldn't be. Mine was cracked on both sides and never leaked, but was replaced under warranty without any problems.
I’m going to wait until I can catch it leaking before I bring mine in. I have less than 0 faith in dealerships so I’m not going to bother until I have a picture of water coming through. Don’t want to waste my time arguing with themNope would have to replace it all. I didn't have leaks as well but if its cracking you will leak eventually.
