Rear window frame cracked
contezl
Have a 2019 ram 1500 rebel with 42k miles and the rear window frame is cracked and leaking water. Seems like a known issue but Ram isn’t doing a recall? @RamCares are you able to support me getting this replaced? I have an extended warranty and they are saying they won’t cover it either. 1700$ price tag doesn’t feel great for a 3 year old truck.
where are you located.. if your insurance has 100% glass coverage they should cover this. I had mine replaced under warranty from the dealer but found out the insurance would cover the window.
Hey there,
We'd be happy to look into this for you. Would you mind sending us a direct message with some more information about what you've done so far with your dealer?
Callie
Ram Cares
Recalls are only mandated for safety issues. Because there are so many with this problem, they may decide to do free repairs, to avoid a class action lawsuit, bu unless there is one, unfortunately, they are not legally obligated to.
This will more than likely never be a recall because it is not a "safety" issue. It is also a very common problem that was supposed to be addressed already by the manufacturer (from what my dealer told me) but it apparently it's hasn't been. Some dealers have been known to replace them with under a "good faith" policy and others will not. If ramcare doesn't help you then I'd suggest calling your insurance company and putting in a claim because it should be covered under glass coverage. Good luck
There is a TSB related to this
I've had the job done under warranty. If your truck is still under warranty like you state, its pretty clear in this TSB that FCA is covering this under warranty. Take this to your dealer
I've attached the TSB in photos for reference
Thanks,
David
Thanks,
David
He has 42,000 miles. Out of warranty.
It is a safety issue if the water intrusion causes black mold.
Take it up with the manufacturer or a lawyer to get the ball rolling then. Good luck with that
He said he has extended warranty. My extended warranty is 5yr/160000km. He's over the factory limited but more than likely still good with an extended.
Cheers
I'm looking into a Mopar Maxcare extended warranty for my truck and it claims it does not cover the window
it seems some progressive movement is being made on getting this issue resolved
Cheers
The extended warranty s don't necessarily cover everything.
