Rear Spacer Lift 1/2"
Hadit55
Michigan
Does anyone know if the below would work with a 2020 4WD Big Horn? Looking at the 1/2" rear spacer. It says they work up to a 2018 RAM.
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
Hadit55
Michigan
Hmm, I mean they look like they would fit but I’m not sure.
If you want something that I know works because I’m running it on my truck it’s these even though they’re 3/4” not 1/2”:
Great feedback. Thank you!
Also just to confirm, you have a standard suspension, correct?
Hadit55
Michigan
Did you get a true .75, or slightly less or more? I see they are polyurethane so I would think they would compress a bit.
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
I actually got a true 3/4” and I have a long bed too so fairly heavy
djevox
VP of Creative Thinking
MD
I have those also. I slightly milled the center for the entire spacer to sit flat on the lower spring perch. I’m not sure that that was necessary for me to do though.
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
Hmm I installed mine very sketchy with some ratchet straps on the coils so I didn’t have a chance to check that 😂 but I can tell you for sure with the weight of the truck on them they sit flat now 😂
