Rear Spacer Lift 1/2"
Hadit55
Michigan
Does anyone know if the below would work with a 2020 4WD Big Horn? Looking at the 1/2" rear spacer. It says they work up to a 2018 RAM.
Hmm, I mean they look like they would fit but I’m not sure.
If you want something that I know works because I’m running it on my truck it’s these even though they’re 3/4” not 1/2”:
Great feedback. Thank you!
Also just to confirm, you have a standard suspension, correct?
Did you get a true .75, or slightly less or more? I see they are polyurethane so I would think they would compress a bit.
I actually got a true 3/4” and I have a long bed too so fairly heavy
I have those also. I slightly milled the center for the entire spacer to sit flat on the lower spring perch. I’m not sure that that was necessary for me to do though.
Hmm I installed mine very sketchy with some ratchet straps on the coils so I didn’t have a chance to check that 😂 but I can tell you for sure with the weight of the truck on them they sit flat now 😂
