R
Rob5589
Guest
I can't tell you what shock to buy since I do not have the needed information on the available units. By research, it is best to call various manufacturers and speak directly to a technician and tell him what you are looking to accomplish.Good info, but I already knew this. And you didn’t really answer. Not trying to be a Dck, but I don’t know how else to say it.
“Research” isn’t an answer.
I mean the only happy medium seems to be falcon shocks from teraflex.
We both know what I don’t like about the ride, it’s got 50 cent white shocks on the rear and preloaded coil on the front. Bouncy mcbounce over bumps. People are quick to blame the “small tire big wheel” but has nothing to do with the truck bouncing around on rough roads. And a 5-6” profile isn’t really that small. Sure it’s smaller but it’s not 24s snd 33s.
When you look at a website it will give you info on "what fits most," so to speak. If you want to optimize your selection and get the very most for your buck, you really need to speak to the builder themselves.
Yours is a unique set up since you have changed the spring rate by using a pre-load type spacer. So now, the one size fits most likely won't apply to you. By adding a pre-load spacer you have also moved your shock away from a neutral position. You have lost down travel but also up travel since the coil is now effectively stiffer (increased rate).
A shock should sit at, or very near, the center on its travel at neutral (parked flat). Moving away from the center significantly changes the damping which will reduce ride comfort. Also remember, the shock controls the majority of ride comfort/compliance.
For tire profile, a 5-6" sidewall is going to be less compliant than 7+ inches. There is no way around that. A 6" sidewall is short for a 6000 lb truck.
Just because it is free, try airing down the tires some and see if you gain a bit of compliance and comfort. Not gonna hurt to try.
