Icecold77
I only ended up having the Ready Lift UCAs out of their 3.5in SST Kit installed. I have the entire kit minus the UCAs if anyone is interested PM me. Before I feed it to the wolf's on EBAY. It's all new in box.
When I went for an alignment it was so slightly out of spec I could've left it. I think the new UCA's helped keep everything within factory angles, considering they are rated up to a 6" lift, 3.5" was peanuts.
And when I had a close look at the factory UCA's, I was glad I swapped them out... just not very confidence inspiring to say the least.
Hey guys, the ball joint angle that everyone should be concerned about is not at ride height. The issue with the ball joint angle is only at full droop. At full droop the angle is much more pronounced. There are two basic methods to achieve lift on the front. Adding a spacer above the strut increases the down travel of the UCAs when at full droop. Effectively the same as adding a longer stut minus increased up travel. Adding a preload spacer within the strut itself does not increase down travel of the UCA since the strut’s max extended length stays the exact same. The up travel is reduced due to the spacer.
If you add a spacer on the top of the strut, do yourself a favor and add UCAs that correct the ball joint angle at full droop. However, if you don’t mind a bit stiffer ride, go with the preload spacer and save some money. A strut compressor will be required if you go this route. Take pictures and compare the ballpoint at full droop. The reason to add UCAs will become clear.
I have the ready lift 2inch preload spacer billet aluminum and I’m having some issues with clunking sounds seems to be more on the passenger side and more noticeable at slower speeds on slightly bumpy pavement. I’m having issues getting it fixed by installer. I posted more info on a thread I postedHey guys, the ball joint angle that everyone should be concerned about is not at ride height. The issue with the ball joint angle is only at full droop. At full droop the angle is much more pronounced. There are two basic methods to achieve lift on the front. Adding a spacer above the strut increases the down travel of the UCAs when at full droop. Effectively the same as adding a longer stut minus increased up travel. Adding a preload spacer within the strut itself does not increase down travel of the UCA since the strut’s max extended length stays the exact same. The up travel is reduced due to the spacer.
Has anyone tried the procomp UCA for 139.00 for the pair? I bought the motofab 2" alum strut spacer, just need UCA before i continue.
Summit racing link: https://www.summitracing.com/parts/...T11NrbKRfWEXyxBGrrNd63C0Ditaa6LwaAmukEALw_wcB
PN: 61181
Installed my Readylift leveling kit with UCAs today. I took a couple pictures at full articulation along the way.
My truck has the ORP so I’m aleady at what I believe is pretty close to maximum angle for the ball joint. This is stock at maximum articulation.
This picture is with the strut spacer installed and new UCA at maximum articulation. The ball joint is not at maximum deflection.
This picture is where I installed the strut spacer and reassembled with the stock UCA (took the extra time just to see...). At this angle, the ball was binding (maximum deflection) and made it impossible to turn the spindle left and right by hand. By taking the time to do this reassured me that the UCAs were a must.
How much height does the off road package give you up front? I have top mount spacers and my full droop is no where near that bad. My ball joint still had much more movement past full droop. I do not have the ORP and when I installed my 2 inch level it almost stayed stock.
Anyone having any bushing / suspension squeaks? I have an inconsistent chirp I keep hearing from the passenger side when the windows are down. Can’t seem to pinpoint it....yet.
any update @troutspinner ? just had the ready lift 2" level with uca"s done to my truck. driving 3 hours on monday to pick it up.
