Rattle on the inside
Hi 19RAMCUMMINS,
I'm sorry to hear of the trouble you are experiencing with your truck. Please let us know via private message if you decide to have your dealer look into this. We would like to have this documented and have a case escalated in your behalf so a Case Specialist can work with your dealer to help find a potential solution.
19RAMCUMMIN,
i purchased a set of chassis ears from amazon. i'm trying to narrow down the noise. i am suspecting the rear cab mounts for the megacab. is your's a megacab also? I'll keep everyone posted when i find it. i'm not letting the dealer tear into it. i'm too anal about people working on my truck. as a 35 year tech, i'll figure it out.
MEGA CAB RATTLE FOUND!!!! AND CURED!!!
ok everyone.. here's the skinny on the rattle that is probably present in almost every 2019 Ram with the mega cab. This ONLY applies to the mega cab truck. The noise, rattle, which sounds like a block of wood bouncing around, golf ball in a plastic jug (my description) etc.. anything that is coming from the underside of the truck, in the rear of the cab. After purchasing a set of electronic chassis ears, I narrowed the noise down the rear cab/body mounts. These are a new design and not the same mount as the rest of the body mounts. The issue lies in how the metal sleeve, inside the mount, bounces off the floor of the cab while hitting sharp bumps. If you remove the 18mm bolt and large washer, you can see the metal sleeve. it's about 3/4" inside diameter. No matter how tight the bolt is, the sleeve will always hit the underside of the body over sharp bumps. So here's the cure. Forget going to the dealer as there isn't an updated bushing, (there was for the 1500 but only the front mount) and it's relatively easy fix. They also won't give two ****s anyway, will track footprints in your truck, waste your time because the booger-eater tech doesn't have a clue. (I've spent 30 years as a certified tech, general foreman of a large government fleet shop, so I've seen plenty of booger-eaters)
Take the large washer that covers the lower portion of the bushing (thick one with some paint pen marks on it) and oversize the hole to at least one inch. Unibit works great. Remove the thin sleeve that's snapped into place, inside the washer, as you'll need this later. Loosen all of the body bolts as you will need to jack up the truck from the rocker panel to separate the body from the bushings. Use some dunnage (2x4) and place it under the rocker panel to spread the load while jacking up the body. Place a towel or rags over it so it won't scratch up the underside. (I'm anal). I used a small handled interior pry bar, and wedged it between the rear body mount and underside of the cab. Do this from the rearward side as there's a nice radius on the cab channel to make it easier. This gives enough room to slide the large/thick washer between the mount and body. Center up the over-sized hole, over the existing metal sleeve that is centered in the bushing. You will see two dimples or indentations on the large metal washer. Place those facing down as to keep the portion of the washer that rests against the body, flat. In other words, the two indents compress the rubber portion of the body mount. The overall goal in this, is to compress the internal sleeve, tight against the floor of the truck when it's torqued. With the over-sized hole in the washer, the sleeve will compress against the body when the bolt is torqued back down. Now I went one further step in eliminating the noise once and for all. I replaced the thin sleeve, back inside the bushing. This gives a little "shelf" around the existing metal sleeve. I added two washers, roughly just over an inch in diameter, to fit over the long bushing bolt. Fender washers are good because of their size. These two washers allow just enough thickness as to make contact with the sleeve, and make it sit flush against the body. (The rubber portions of the mount have a metal structure inside, so they don't crush easily). You can't remove the thick factory washer on the bolt, which you don't want to do anyway. Torque to 90 ft lbs. (factory spec). Now there are two things I will mention. The repair manual states that the bushing bolts are a one time use. Like a torque to yield head bolt. I say poo-poo to that so I used them again. I can't see the logic, however that's what the factory states. They are not a stretch torque value. Your decision. Secondly, by re-locating the large/thick washer up top, the rubber portion of the bushing is exposed to the elements. Again, I don't see this as an issue. I torqued all bolts back to 90 ft. lbs and it's as quiet as it should be. The noise is now gone and I don't foresee any other issues creeping up. Please spread this around to any other folks that might be experiencing this. I would have attached some pics, however it's pretty straight forward. I hope this helps out. If you email me at [email protected], I will send some pics of what I did.
Hi alramguy,
Congrats on your new truck! We understand your concern. We're happy to help you find a dealer in order to get this properly addressed. You can enter your zip code here to view all certified Ram dealerships in your area: https://www.ramtrucks.com/find-dealer.html. If you see any dealerships that have received a Customer First award this means that this dealer has achieved the highest level of customer experience recognition in five core areas: people, facility, processes, customer metrics and training certification. You're welcome to send us a private message as well and we'll gladly assist with that process.
Lydia
Ram Social Care Specialist
Lydia lives in India and doesn't "care" about your Ram.
So when I picked up my truck from Ram I got a chance to talk to tech and he showed me the I guess what is a star case? and a thread or forum the techs are a part of and he confirmed it is a know issue pinpointed to the pass side rear cab mounts.
This is what they wrote:
"The rattle is coming from rear cab mounts. due to design oversight the center spacer tube rattles up and down against the top mounting plate portion of the mount and until a redesign of the mount is available this noise will not be able to be fixed."
"tried removing the lower black washer with the dimples and placing it on top with the dimples down to seperate the center spacer from the cab. Then we reinstalled the bolt with 2 washers between the center spacer and the large washer on the bolt. We were trying to clamp the center spacer between the silver top cap and the bolt. Still didn't change the concern. With the mount being fluid filled I can't remove the the center spacer to cut it down. Agreed that a redesigned mount is needed."
"wondering if this was the same issue for the star case that disappeared for a rattle at the A lar and they wanted you to replace front cab mounts.I am getting no where with star on concern they think the wrong mount was installed in location of rear of cab, knowing they are physically different mounts from the other mounts on cab."
"finally after 3rd revision of rear cab mounts the noise is no longer present"
Not sure what 3rd revision is but would love to find out. Hopefully my tech/dealer will find out and let me know if and when a redesign or fix is present.
. I just popped it off again, sounds bad when 18 degrees out, just lift up steadily, keep it level (it has some flex), and you'll hear them "snap" loose...notice the green adhesive tape pieces I put on.
I removed the center grill today to solve a similar rattle issue. For the 2021 Limited, it seems the metal tabs for the grill weren’t bent tightly enough. I used the foam tape and tightened the bend on the tabs. Hopefully it will be quiet now.
Look what my dealer in Harrisburg PA did to my console when they removed the bolt that was rolling around in my heater box. I waited over 7 months to take the truck in to have the annoying noise fixed because I knew they would damage something when fixing the factory defect.
They even got grease all over the front passenger seat. This photo is after I cleaned the grease off. It left some small permanent stains.
Hey, do you have the work order for the bokt rolling around? My 2020 bighorn has started doing this.
