kapinallinen2
- Jan 16, 2019
- Location
- Southern Maryland.
13.5 city, 14-16 hwy.
yea idk WTH it is, i have done all i can to fix the issue but no luck. and im making a jump soon to 35's and either 20's or 18's which will be 30-40lbs extra per corner so im scared to see what that does .That's pretty bad. I'm getting 11.5 MPG, 99% city with my TRX.
That’s exactly what I see on my ‘22 Rebel non e-torque. I couldn’t see 20 mpg going downhill with a 30 mph tailwind.13.5 city, 14-16 hwy.
Wish I could! Love everything about the TRX.Well, I guess it's time for a TRX. It already has 35's and I guarantee you won't be wondering why it gets bad fuel economy.![]()
The cap less does not make a difference in fuel consumption, you would get an warning if the gas cap was missing or if the cap less tank would not seal.I have a 2019 ( new to me ) Ram 1500 limited only missing a few bells and whistles. I am noticing horrible fuel economy compared to my 2015 Ram 1500 big horn. I do have an after market exhaust on that truck and an after market COI on it as well I did notice not only HP gains but fuel economy as well. It would take me a couple of days after filling up to drop below a full tank of gas and in the new limited it dropped below after only one day of driving to and from work. I only live at most 20 mins from my job and I take the highway to get there. I put non ethanol 89 in my truck. I do not have the ETorq on mine. I’m wondering if the weight of the air ride suspension system is playing a factor in the poor fuel economy or if it is due to the “cap less” fuel system it has is letting the gas escape faster. I do not know what is causing it but I am disappointed/disgusted that my 2015 was getting way better fuel efficiency
2019 limited 3.92 20% city and rest hwy 22 gallon tank 5.7 non-et and I avg 11-13 mpg sucks but I’m learning to live with it. Next truck will be a diesel. My buddy just picked up the new gmc sierra with the 3.0- or 3.2 I can’t remember and he’s getting 24mpg city and 28-30 hwy same tank size but I’m not sure his gear ratio and that thing still has some pull and get up and go!
I’ve looked at many aspects and reasons why my gas mileage might be this bad but I’ve compared it to other owners with same truck/ gears and LARGER tires (35’s) and they are able to squeeze more out of their rigs.Now that I read your signature it's likely your modifications are what is making your fuel economy so low.
First the 33 inch nitro grabbers are significantly heaver than the stock tires and the tread design is not conducive to the best fuel economy. When I switched to BFG ATs of the same size on my last truck it easily cost me at least 2 mpg. Your switch to a larger than factory tire likely cost you more.
Also, if you didn't recalibrate for the larger tires you are probably getting better mpg than what you are calculating as you are actually traveling farther than what the odometer says on each tank. I believe the stock 20s in 2019 were 275/55-20 which is 30.8 inch diameter. Without recalibrating, your speedometer will read 60 but you will really be traveling 64.3.
The mileage your friend is claiming on his Chevy is exactly what the window sticker claims for EPA mileage so I would take his claims with a grain of salt since I've never owned a vehicle that reliably reached the EPA estimate on the window sticker.
Also, it's a proven fact that adding a louder muffler and deleting the resonator adds about 10 lbs to your right foot making it difficult to let off the gas pedal.
Sheesh, what can you see out of the truck at night with a 5% tint as well as the windshield at 35%?2019 limited 3.92 20% city and rest hwy 22 gallon tank 5.7 non-et and I avg 11-13 mpg sucks but I’m learning to live with it. Next truck will be a diesel. My buddy just picked up the new gmc sierra with the 3.0- or 3.2 I can’t remember and he’s getting 24mpg city and 28-30 hwy same tank size but I’m not sure his gear ratio and that thing still has some pull and get up and go!
It's not bad. I actually prefer the tinted windshield at night over not tinted. Cuts down headlight glare significantly, and the ******* who doesnr aim headlights after lifting their truck isn't as annoying. I left my front doors at 20%, but have 35% windshield and 5% everywhere else. LED headlights are a must if you do go that dark. Most people who ride in my truck don't even realize the windshield is tinted unless I tell themSheesh, what can you see out of the truck at night with a 5% tint as well as the windshield at 35%?
Other than the bigger tires, have you lifted or leveled? Tires, lift/level all decreases mpg’s.
My almost bone stock 2023 Ltd et 4x gets a lie-o-meter calculated 14-15 in town and 18 at 75 on the highway, 3.92 gears.
Explain “3500 trailer load“ your pulling with your truck please.I suspect your buddy with the Chevy would also get much better than 11-13 in your Ram. I've never gotten that poor of mileage on any of the 4 hemi Rams I have owned. My current Ram with 3.92s will get 13 or better when towing a 3500 trailer load.
At night the front windshield is barely noticeable of tint, really all it does is cuts down glare from on coming vehicles. But side and rear windows aren’t bad either.Sheesh, what can you see out of the truck at night with a 5% tint as well as the windshield at 35%?
What made you change the temp sensor in the first place, was it defective, throw a code?Idk if any of yall have fixed the issue but I got a 2020 ram 1500 5.7 hemi no e torque sport edition. I was seeing the same low mpg. I changed my ambient air temperature sensor and I instantly gained 5+ mpg. Idk if it was just so weird kink with my truck of something. It's worth a shot tho. Like a 15 dollar part easy install in 5 mins. Goodluck
Did you unhook the battery when you replaced the sensor?Idk if any of yall have fixed the issue but I got a 2020 ram 1500 5.7 hemi no e torque sport edition. I was seeing the same low mpg. I changed my ambient air temperature sensor and I instantly gained 5+ mpg. Idk if it was just so weird kink with my truck of something. It's worth a shot tho. Like a 15 dollar part easy install in 5 mins. Goodluck
