BigD
- Apr 23, 2020
I also have the Bridgestone Duelers.I have the Bridgestone duelers
I got 21,000 on my truck right now & my tires are at like 8/32. Damn, u must do alot of burnouts or brake stands or something.
born 1955?
I have etorque 2019 5.7 4wd crew cab. I bought it 2 weeks ago and I am ready to sell. Fuel mpg is not as advertised. I get 11 / 16. Not the 17/22 as advertised. Has anyone found a solution.I've seen reports of others getting poor gas mileage in their 5th Generation Rams. Mine is horrible. Has anyone else gotten a dealer to figure out what's wrong with this truck?
I've had my truck in the shop twice now for this issue. The Ram technicians are not able to find anything wrong with the truck.
It is a 2019 ram 1500 limited 4x4 crew cab with eTorque engine. Fuel economy is supposed to be 17 city, 22 highway.
I have the active suspension, and every option imaginable. 12" touch screen (which I would not recommend after living with it).
I only get 12-13 mpg city and 15-16mpg highway.
I have the 3.92 rear axle with anti-spin diff.
Eco mode almost never turns on in this new truck.
I have no performance options other than what the truck came with.
I have 12,500 miles on it now.
My 2016 ram quad cab with 5.7 hemi 4x4 got 20mpg or better consistently on the highway thanks to the eco mode.
I should be getting at least within 1 to 2 mpg of what is stated. My 2016 truck promised 20mpg and I got better.
I drive conservatively. I drive mostly highway. I don't idle the truck.
I thought the eTorque would be the way to go. I would not recommend it.
I've owned 4 of these trucks, each one better than the last, until this latest one.
I was given a loaner 2019 Ram 1500 with the Hemi, crew cab, same as my truck, but no eTorque option. I towed a trailer with that loaner truck for 250 miles and averaged 19.5mpg in tow/haul mode. It was the same year as mine 4x4 with the crew cab and hemi, and it got much better gas mileage. The only difference is mine has the eTorque, and this loaner did not. I can't get gas mileage that good in my truck, when it's empty and riding steady at 65mph on the highway. When I tow, I get 12 on the highway.
Something is wrong with my truck that is not wrong with all of them. Has anyone else experienced this and have you gotten it properly fixed? I'm at the point where I'm fighting with my dealer and I need to tell him what it is. He has put the OBD tester on it and says it has no codes.
Umm, Do you use remote start?I have etorque 2019 5.7 4wd crew cab. I bought it 2 weeks ago and I am ready to sell. Fuel mpg is not as advertised. I get 11 / 16. Not the 17/22 as advertised. Has anyone found a solution.
I found the perfect solution- it’s in my signature below.I have etorque 2019 5.7 4wd crew cab. I bought it 2 weeks ago and I am ready to sell. Fuel mpg is not as advertised. I get 11 / 16. Not the 17/22 as advertised. Has anyone found a solution.
This must be a joke or your smoking something. I got the exact same truck but I have a 2020. I even got the 3.92 gears & I never get worse than 15 mpg city driving it like Dale Earnhardt! I can easily get 19 or 20 mpg highway no problem.I have etorque 2019 5.7 4wd crew cab. I bought it 2 weeks ago and I am ready to sell. Fuel mpg is not as advertised. I get 11 / 16. Not the 17/22 as advertised. Has anyone found a solution.
I hear that the v6 turbo from ford is a good choice as long as one doesn't gun it?I have etorque 2019 5.7 4wd crew cab. I bought it 2 weeks ago and I am ready to sell. Fuel mpg is not as advertised. I get 11 / 16. Not the 17/22 as advertised. Has anyone found a solution.
Trying to compare one Ram to another for MPG is a no win game. No two trucks, even equipped the same and driven by the same driver on the same road and in the same way will get the same MPG. And, if they do, it is a rarify, not a rule. It is impossible, even in a speed shop to make two engines, let alone two trucks, identical. Just ask a NASCAR team. Beside that, you are asking a person with a similar truck, what kind if MPG he gits with his driving style, and on his commute.I have etorque 2019 5.7 4wd crew cab. I bought it 2 weeks ago and I am ready to sell. Fuel mpg is not as advertised. I get 11 / 16. Not the 17/22 as advertised. Has anyone found a solution.
The sure fire solution is to just not start the motor. It is a 5.7 V8 and uses gas. Just tow it around with another truck and it's milage will shoot up.I have etorque 2019 5.7 4wd crew cab. I bought it 2 weeks ago and I am ready to sell. Fuel mpg is not as advertised. I get 11 / 16. Not the 17/22 as advertised. Has anyone found a solution.
I had one as a loaner for about a week. It was a tad bit better on MPG than my truck, but I don’t have A.s.s, that one did.I hear that the v6 turbo from ford is a good choice as long as one doesn't gun it?
i once asked a friend who had just brought a new corvette how much was the mpg. he said "if you are worried about mpg do not buy it".Trying to compare one Ram to another for MPG is a no win game. No two trucks, even equipped the same and driven by the same driver on the same road and in the same way will get the same MPG. And, if they do, it is a rarify, not a rule. It is impossible, even in a speed shop to make two engines, let alone two trucks, identical. Just ask a NASCAR team. Beside that, you are asking a person with a similar truck, what kind if MPG he gits with his driving style, and on his commute.
Besides, if you got the truck thinking that the government sticker was accurate on all similar Rams, then you might want to rethink. It is nothing more than an educated guess in a perfect truck, and under ideal conditions. It is just a number to keep Uncle Sam happy. Want better MPG, change driving habits as much as you can to maximize it.
Oh and, you might look at a Prius plug-in Hybrid if you want good MPG.![]()
You won't get only 15 highway unless you drive like a maniac.So many posts about it's a truck what did you expect... everyone's got a limit. Nobody would accept 1 mpg. How about 2 mpg? 10? Seems like 90% are ok with at least 15. Everybodys got a different number theyre comfortable with. Some people want the number on the window sticker. Some people have reasonable expectations of high teens and get low teens. I understand why theyd be upset with that. I get 20+ in summer and am very happy. If i only got 15 highway Id be pissed.
