JF19Longhorn
On flat ground @ 70mph I'm lucky to see 16-18mpg on the instant readout. The MDS never kicks in above 45'ishmph unless I'm going downhill or slowing down and have a strong tailwind.
Curious to see how this affects your mpgsYeah I'm about the same as you with MPG's. Flat roads cruising 65 is about 23-26mpgs. at 70 it's about 21-24mpg if it's flat. I'm about to level the front of mine 2 inches so I'll see if that decreases this great mileage I've been getting. I didn't want to but I was tired of looking at the raked look. I had the rear lowered, but I didn't like how it drove and when I towed anything it was horrible, so I decided to level the front a little.
I'll let you know sir. It's funny, I've noticed that we are usually on the same threads doing our homework before we do any mods HAHA.Curious to see how this affects your mpgs
I feel you, I always buy extended warranties then mod itHaha yea. I prob won’t be doing much modding until warranty expires. So you can go first![]()
Probably should of went with a A/T tire but damn the M/Ts look good, thanks for the replyThe tires will definitely hurt mpg. Especially if they are load range E, as they will weight a lot more.
Yes sir. They do!Probably should of went with a A/T tire but damn the M/Ts look good, thanks for the reply
Yeah those tires probably weigh in at 70 pounds a piece but they do look good. As long as it puts a smile on your face you are good right? HahaProbably should of went with a A/T tire but damn the M/Ts look good, thanks for the reply
Just letting you know, I just finished the 2" motofab lift on my truck. Here comes the real test of this drops my MPG's or not haha. I don't think it looks bad at all with the stock tires so I'm going to use them until I've worn them out.Curious to see how this affects your mpgs
I’ll have to see how it treats me on the highway. I have a feeling it’s going to drop a bit for sure.I did that same leveling kit a month ago and haven't really noticed much change, still in the mid 18s for mixed driving. At interstate speeds of 70+ I think the economy may be dropping a bit with the level....but I only drive on the interstate about 3 times a year. On relatively flat highways of 60-65mph the truck is usually about 21-22mpg in 8th gear.
I'm also sticking with the stock Wildpeaks until they wear out, they aren't my favorite tires, but they aren't bad either. Haven't had them in the snow yet though....
More than you're prepared to see for sure!I’ll have to see how it treats me on the highway. I have a feeling it’s going to drop a bit for sure.
I think if I get an aggressive tire it might drop. As of right now I’m not doing horrible. I’ve put about 100 miles since the leveling kit. It’s tough getting anything above this which before it was a bit easier but the wind resistance has increased slightly.More than you're prepared to see for sure!
oh wow didn't realize our screen did that!I am actually happy with my gas mileage. This is average driving for 2 weeks, town and highway mixed.
