Hockeydad
No air ride lowered springs in backLove that look, do you have the 4 corner air suspension?
Would like to drop the back on mine but worried about air suspension.
Thank you. Yes it is the IHC 3/5, however I haven't cut the rear springs yet. I think it still needs to come down a inch in the rear.JWiens19Hemi
Guessing that's the IHC 3/5 kit? Looks good. I've got a Granite CC 2wd also
It's the IHC 3/5.What size drop is that
In my case, yes it’s a pavement princess, 2wd and going the street truck route. I’ve had my lifted trucks and done the whole off road thing. Back in my young days. Now I’m older, married and with 2 small kids. Just easier for the entire family to get into the truck.
Looks fantastic - Damn good looking truck! NICE Stance brother.Maxtrac 2/4 on my 2wd. Still have to install airlift 1000 helper bags and wheel spacers.
Man, that truck is HOT!Maxtrac 2/4 on my 2wd. Still have to install airlift 1000 helper bags and wheel spacers.
did you install the kit ?? any cutting or welding involved ?? can it be returned to stock height for resale ??Thank you. Yes it is the IHC 3/5, however I haven't cut the rear springs yet. I think it still needs to come down a inch in the rear.
What brand rear lowering springs are you running? Did you notice any pluses/ minuses in ride quality after installing the rear springs? Your truck looks great!Hey guys lets see a pic of your lowered RamView attachment 40104View attachment 40105
I think these trucks look good with the rake, whether lowered or stock2" Maxtrac front drop shocks
2" Maxtrac rear lowering springs
Fresh install, haven't measured after, I'll wait for the rear springs to settle.
I like the rake, I know most don't ...
That looks great. Did the alignment get back to spec? I’ve heard from several others after the 2” front drop, the camber is still negative.Maxtrac front drop shocks - set @ 2" drop
Got my alignment spot on. With me in the drivers seat, camber evens out to -0.3 on each side. I believe I still had wiggle room as well. I'd be okay with almost a degree of negative camber (just my own opinion here). Factory settings want to see zero camber nominal and 5 degrees of caster nominal.That looks great. Did the alignment get back to spec? I’ve heard from several others after the 2” front drop, the camber is still negative.
