Careful Everyone with the pedal commander. started off great and I loved it until it accelerated on its own. I even had it swapped out with a replacement but same issue. I wish it would have worked because it was awesome when it did.
No, you could look at the Edge Pulsar for that.Can the pedal commander also do tire calibration?
Thank You!No, you could look at the Edge Pulsar for that.
It is wired in with a power actuator. Turn it off for the highway for a nice quite ride and then open it up for tunnels and passing mustangs.
I was just reading something else and realised I should have also suggested the Tazer DT as well.Thank You!
This happened to me also the other day. Scary at first! Another issues I'm having is that it throws several dash alerts about every 3rd time I make an adjustment to the PC settings. I always do changes while in park and running. Anyone else seeing this?
I stopped changing the settings on my PC and just leave it on a single setting and I haven't had any issues. I still feel adjusting the settings should throw all kinds of issues. Hopefully the PC company is addressing these issues and will release an update for our devices. At this time I would suggest folks NOT purchase the PC for the 2019 RAM 1500, at least not until these issues are resolved. Unacceptable to have your vehicle just start accelerating on its own.
				 pedalcommander.com
					pedalcommander.com
				There's other products working that have not had those issues just look at some other threadsRight, need that lag gone, and PC will do that I believe. Referring to the unwanted rapid acceleration mentioned earlier, that and it was throwing codes, lighting up dashboards like crazy, ect .
The PC will not throw codes and does not rapidly accelerate...it has been perfect to use.Right, need that lag gone, and PC will do that I believe. Referring to the unwanted rapid acceleration mentioned earlier, that and it was throwing codes, lighting up dashboards like crazy, ect .
The PC is much more reliable, but can still cause throttle issues and throw codes. That being said, PC customer support is great. My unit started acting up after 6 months, would throw codes and accelerate on its own very slowly. Had an RMA # and shipping label in a days time with no questions asked. Sent the old unit in, recieved the new unit the end of that week. Installed the new unit and no issues since.The PC will not throw codes and does not rapidly accelerate...it has been perfect to use.
