All trim levels are capable of having it added.How can I find out if my 22 big horn is capable of having oem passive entry added. Thanks.
it is a long read but might helpHow can I find out if my 22 big horn is capable of having oem passive entry added. Thanks.
They are 100% wrong. They probably just added the handles or don't know what they are doing. This isn't something a stealership typically installs. You need the harness too. You will probably have to do it yourself.I Have my 22 big horn at two different the dealerships and one of them installed the OEM passive entry but they can't get it to program after repeated attemps to program it unsuccesfully they sent it to a second dealership and they can't get it to work as well. They have had my truck for three weeks and can't get it to work. The service manager at another dealership I called told me that if it did not come from factory with the wiring for it, the passive entry can not be programmed even if an oem one was installed. I am at a loss with this.
Assuming that they initially installed the correct door handles, door harnesses, rear bumper antenna, and rear bumper harness, no dealership will be able to program it to work. You have to use AlfaOBD or Jscan to activate it yourself.I Have my 22 big horn at two different the dealerships and one of them installed the OEM passive entry but they can't get it to program after repeated attemps to program it unsuccesfully they sent it to a second dealership and they can't get it to work as well. They have had my truck for three weeks and can't get it to work. The service manager at another dealership I called told me that if it did not come from factory with the wiring for it, the passive entry can not be programmed even if an oem one was installed. I am at a loss with this.
Unless the DEALERSHIP(I fixed the spelling for you) has an aftermarket tool to program the system they can't do it. I have done a few at the DEALERSHIP, including one for the Stellantis reps dad.They are 100% wrong. They probably just added the handles or don't know what they are doing. This isn't something a stealership typically installs. You need the harness too. You will probably have to do it yourself.
Thank YouAssuming that they initially installed the correct door handles, door harnesses, rear bumper antenna, and rear bumper harness, no dealership will be able to program it to work. You have to use AlfaOBD or Jscan to activate it yourself.
All of the current info you need is in this thread:
Adding Passive Entry: How-to
If you've seen the original thread on adding passive entry, HERE, you are likely well aware of the issues with getting it to work on the newer trucks that didn’t come with it from the factory. This thread will walk you through getting it to work on the 5th gen DT’s (and the HD trucks) just as it...5thgenrams.com
Nope, didn't fix it.Unless the DEALERSHIP(I fixed the spelling for you) has an aftermarket tool to program the system they can't do it. I have done a few at the DEALERSHIP, including one for the Stellantis reps dad.
CoolNope, didn't fix it.
NiceCool
Are you in south Florida by any chance..lolUnless the DEALERSHIP(I fixed the spelling for you) has an aftermarket tool to program the system they can't do it. I have done a few at the DEALERSHIP, including one for the Stellantis reps dad.
There was a eBay seller that was selling oem door harnesses and handles with caps and said the dealer had to add a sales code “GXD” to get it to work. I did mine with Alfa, so I can’t verify that’s the case but before I found this site I was looking at that.Assuming that they initially installed the correct door handles, door harnesses, rear bumper antenna, and rear bumper harness, no dealership will be able to program it to work. You have to use AlfaOBD or Jscan to activate it yourself.
Thank you I will try to find someone with the alfaobd to install it.@Tango51 you should verify what all the stealership you when to installed. They might not realize you need a third party software to program this.
Being a stealership they may believe that whatever they have is all that is required. Don't let the stealership run up extra unnecessary diagnostic time that will be fruitless. You know how stealerships can be....
Just touch base with them, make sure the stealership installs all the parts as listed in the thread and you take it from there for programming.
"GXD" isn't an option that could be added. Be glad you didn't go that way.There was a eBay seller that was selling oem door harnesses and handles with caps and said the dealer had to add a sales code “GXD” to get it to work. I did mine with Alfa, so I can’t verify that’s the case but before I found this site I was looking at that.
Funny that you say that because I went back to look for it on eBay and he is still selling the kit on there and that’s the sales code he has listed. Glad I bought the parts and Alfa. Alfa has been useful for so much more on this truck"GXD" isn't an option that could be added. Be glad you didn't go that way.
Hello,I Have my 22 big horn at two different the dealerships and one of them installed the OEM passive entry but they can't get it to program after repeated attemps to program it unsuccesfully they sent it to a second dealership and they can't get it to work as well. They have had my truck for three weeks and can't get it to work. The service manager at another dealership I called told me that if it did not come from factory with the wiring for it, the passive entry can not be programmed even if an oem one was installed. I am at a loss with this.
