Is the leak coming from the oil filter? That is right above the steering rackTrying to get some help with diagnosing the leak. I'm guessing it's oil. Noticed a slow leak and have lost about two quarts judging by the dipstick.
It's dripping off this part, not sure what it is. See attached pics and let me know if you have any direction/wisdom before I take it in.
Thanks
Sent from my Moto Z (2) using Tapatalk
Either that or you just changed the oil and didn't clean it off the rack after changing the filter.You might have a bad seal on your oil filter.
Oil filter is above that part. I had the same problem....my oil filter wasn't tightened down all of the way.Trying to get some help with diagnosing the leak. I'm guessing it's oil. Noticed a slow leak and have lost about two quarts judging by the dipstick.
Thanks
I'm no expert, but it looks like it's a 59.Trying to get some help with diagnosing the leak. I'm guessing it's oil. Noticed a slow leak and have lost about two quarts judging by the dipstick.
Thanks
Ah yes! That damn 59 module...keeps shedding tears Evey time I turn it on!I'm no expert, but it looks like it's a 59.
My issue was a loose oil pressure sensor above the oil filter. Wasnt even hand tightI am having this same issue right now? Was it an improperly installed oil filter for you?
Yes, that's what it is and I just tightened it some. Mine started out as just a week, but eventually was dripping on the ground. For quite a while I thought the oil filter had a slight leak since the filter was coated during oil changes but no drips.Was it this? I was helping a friend with her Laramie and noticed this weeping above her oil filter, I'm assuming that is the oil pressure sensor?
Was your fix just tightening or replacing it? Right now it's just weeping around it, no drips making it down.
I got about two full turns out of mine and it still wasn't super tight. But I couldn't get connector off and didn't want to twist wires too much. It's been dry ever sinceCool, thanks man, I'll do that, she like me rather handle something so minor at home than the dealership.
