Oil Leaking from this - What is it?
Ben33
Trying to get some help with diagnosing the leak. I'm guessing it's oil. Noticed a slow leak and have lost about two quarts judging by the dipstick.
It's dripping off this part, not sure what it is. See attached pics and let me know if you have any direction/wisdom before I take it in.
Thanks
Hawk375
Rack and pinion gear by the part number
jdefoe0424
Illinois
Thanks
Is the leak coming from the oil filter? That is right above the steering rack
Sent from my Moto Z (2) using Tapatalk
vincentw56
You might have a bad seal on your oil filter.
mikeru82
The Palouse
Either that or you just changed the oil and didn't clean it off the rack after changing the filter.
Biga
Cincinnati
It's probably coming off the oil filter, I had oil their as well after the dealer changed the oil. I crawed under the truck and tightened the filter and leak was gone. Mine was just a drip though, oil was not low.
SD Rebel
San Diego, CA
Leaking oil filter, not likely the power steering rack since it's electric.
PowerJrod
Las Vegas NV
Thanks
Oil filter is above that part. I had the same problem....my oil filter wasn't tightened down all of the way.
c3k
Thanks
I'm no expert, but it looks like it's a 59.
novasteel
I am having this same issue right now? Was it an improperly installed oil filter for you?
My issue was a loose oil pressure sensor above the oil filter. Wasnt even hand tight
novasteel
I just had them replace my oil filter as it was loose. I haven't checked the sensor yet as it doesn't appear that there is any residue around it but once it stops raining in the next few days I will take a look at that as well.
SD Rebel
San Diego, CA
Was it this? I was helping a friend with her Laramie and noticed this weeping above her oil filter, I'm assuming that is the oil pressure sensor?
Was your fix just tightening or replacing it? Right now it's just weeping around it, no drips making it down.
Yes, that's what it is and I just tightened it some. Mine started out as just a week, but eventually was dripping on the ground. For quite a while I thought the oil filter had a slight leak since the filter was coated during oil changes but no drips.
SD Rebel
San Diego, CA
Cool, thanks man, I'll do that, she like me rather handle something so minor at home than the dealership.
I got about two full turns out of mine and it still wasn't super tight. But I couldn't get connector off and didn't want to twist wires too much. It's been dry ever since
SD Rebel
San Diego, CA
Wow, that's shocking how loose it got. I guess the wires not being disconnected isn't an issue if it got looser over time (wires would be in the same location since install). Unless it was installed too loose to begin with?
Assuming standard clockwise thread?
